alijahed Posted April 23, 2014 Share Posted April 23, 2014 Hi All, I am experiencing an interesting problem in Inventor!!! Have you noticed when you measure the angles on your isometric views it is wrong! Instead of being 60 and 120 degree it's got a funny dimensions!!! Please see below and the attached files. Part1.zip Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 23, 2014 Share Posted April 23, 2014 Are you using True dimension type or are you using Projected dimension type? Quote Link to comment Share on other sites More sharing options...
alijahed Posted April 23, 2014 Author Share Posted April 23, 2014 It is not only about that when you export it as DWG the angles are not right! Quote Link to comment Share on other sites More sharing options...
alijahed Posted March 17, 2015 Author Share Posted March 17, 2015 I still have this problem unsolved! To me it is a big problem. Just draw something in Inventor then export it to dwg file to see. Quote Link to comment Share on other sites More sharing options...
ecshclark Posted March 20, 2015 Share Posted March 20, 2015 Try edit view. select the change view orientation icon, select the isometric view corner on the view cube, then select Finish Custom View. See if that corrects your drawing view. Quote Link to comment Share on other sites More sharing options...
alijahed Posted March 21, 2015 Author Share Posted March 21, 2015 No mate, This is an internal error in Inventor and apparently nobody has noticed this yet! Quote Link to comment Share on other sites More sharing options...
gbradley Posted March 24, 2015 Share Posted March 24, 2015 I copied this from Inventor 2015 to AutoCad, and I also see a difference. So at least you know your not crazy. Quote Link to comment Share on other sites More sharing options...
alijahed Posted March 24, 2015 Author Share Posted March 24, 2015 I know! I am going to raise it in Autodesk Forum Quote Link to comment Share on other sites More sharing options...
gbradley Posted March 25, 2015 Share Posted March 25, 2015 As noted on the AutoDesk Forum, the problem is with the projected ISO views. If the baseview ISO Top Right is chosen, then you get nice square angles. This isn't a big issue for me, but I find it interesting. Quote Link to comment Share on other sites More sharing options...
alijahed Posted March 25, 2015 Author Share Posted March 25, 2015 Thanks I just saw all of that. Quote Link to comment Share on other sites More sharing options...
gbradley Posted March 27, 2015 Share Posted March 27, 2015 It's fixed in Autodesk Inventor 2016 Quote Link to comment Share on other sites More sharing options...
