Frannym Posted April 23, 2014 Share Posted April 23, 2014 Hi All, Trying to copy a section of a drawing intoa new drawing. I can copy via the clipboard & copy selection and I can see the drawing appear but when I click on the new drawing and try to paste it nothing happens. I have tried the cp command etc but nothing happens. I have read through the past posts related to this but still cannot get this drawing to copy over...any help greatly appreciated. Many thanks Franny Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 23, 2014 Share Posted April 23, 2014 Any chance the old drawing might have been created and/or revised using AutoCAD 2007? Here's another option. WBlock out the portion of the old drawing you need, saving it under a different name, then insert it into the new drawing. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 23, 2014 Share Posted April 23, 2014 With the drawings open side-by-side select the geometry you want to copy and the click and hold on one of the lines. Drag to the new drawing. Attach your file here if you can't figure it out. Quote Link to comment Share on other sites More sharing options...
guran Posted April 23, 2014 Share Posted April 23, 2014 Have you tried to do a zoom extents after the paste? Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 23, 2014 Share Posted April 23, 2014 Well as long as we're throwing out all the possibilities....perhaps the pasted objects ended up on a layer that was turned off or frozen. Quote Link to comment Share on other sites More sharing options...
Dana W Posted April 23, 2014 Share Posted April 23, 2014 Try copy with base point then paste. It seems to work well where the simple copy/paste operation fails, like when the drawings are open in two different instances of AutoCad. I have even had copy/paste fail from one drawing to another in the same AutoCad window. As others have said though, it is likely that the pasted object ended up either at 0,0 or way out Northwest of Jupiter. Quote Link to comment Share on other sites More sharing options...
rkent Posted April 23, 2014 Share Posted April 23, 2014 Well as long as we're throwing out all the possibilities....perhaps the pasted objects ended up on a layer that was turned off or frozen. This would be my guess as well. After pasting thaw and turn on all layers, zoom extents. Quote Link to comment Share on other sites More sharing options...
Ski_Me Posted April 24, 2014 Share Posted April 24, 2014 OMG copy and paste plaaaaese. This is autocad you copy and paste text not objects. How bout XREF? Type xref in the command line, then select attach. The rest of the procedure works just like the insert command. Just follow the prompts find your drawing and you have what you need. Create a layer for the old drawing if you want then you can turn it on and off if you want. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 24, 2014 Share Posted April 24, 2014 Many users rely on Copy/Paste to bring non-text objects from one drawing to another. Quote Link to comment Share on other sites More sharing options...
JerryG Posted April 24, 2014 Share Posted April 24, 2014 Never heard that one either Ski Why would I xref a simple object into a drawing? Say like a symbol for a Fire Hydrant or pipe line etc. I can still turn it off and on using layers. Quote Link to comment Share on other sites More sharing options...
Ski_Me Posted April 28, 2014 Share Posted April 28, 2014 Many users rely on Copy/Paste to bring non-text objects from one drawing to another. Ok I can see that. But the OP wants to copy and paste part of a existing drawing which is way bigger that an object that may contain 3 or 4 layers and a little geometry. I just think xref the drawing in would be way easier. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 28, 2014 Share Posted April 28, 2014 I still don't see a problem. The clipboard can hold a lot of data. I can't advise whether or not an xref would be a better choice without see the two drawings first. You have a crystal ball? LoL Quote Link to comment Share on other sites More sharing options...
