Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Super Member
    Sengna's Computer Details
    Window 7
    8 GB
    AutoCAD 2016
    Jun 2012
    USA
    530
    Default Pump symbol for one line diagram? which one is correct?
    what is the different use purpose between these 2 pumps, which one can i use for to show just general pump one one line diagram? i want to show a pump with 3" pipe outlet from the pump.
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    Is this a homework question?
    Using a very small amount of logic here, a one line diagram shows only a little detail, whereas plan, profile, section, and/or an actual detail sheet shows, well, more detail.
    If I were a betting man, I'd say the symbol on the right is more generic, and thus should be used for a one line diagram. In most one line diagrams I've worked with, the diagram doesn't represent the pipe sizes being used, but the individual pipe segment labels often specify the size for you, hence the resultant diagram.
    HTH
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    It may also depend on the type of pump. Examples: centrifugal, air diaphragm, vacuum, gear or screw pump.
    Super Member
    Window 7
    8 GB
    AutoCAD 2016
    Jun 2012
    USA
    530
    Quote Originally Posted by BlackBox View Post
    HTH
    This is the real world question, I am creating one line diagram from what i saw on the field. i was going to use the pump on the right side too, but just want to make sure if the one on the left represent the same meaning, on google search it was called: "Centrifugal" not sure what that mean?. I want to show pumps with pipe line size call out and some valves. The pump has outlet and inlet.
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    Use a symbol that looks like this.
  6. #6
    Super Member
    Window 7
    8 GB
    AutoCAD 2016
    Jun 2012
    USA
    530
    Attachment 48301
    Hi Remak, is this regular pump (In and Out inlets)? not the Centrifugal pump? yes or no
  7. #7
    Super Member
    Window 7
    8 GB
    AutoCAD 2016
    Jun 2012
    USA
    530
    viking pump.JPG Need symbol to represent this type of pump?
  8. #8
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,096
    If it's schematic then a box would even suffice as long as it's tagged/labeled properly. There's not real right or wrong way as long as some type of symbol is used that can then be referenced to the pump information in a schedule. ReMark's schematic pump is the most common and considered the industry standard.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  9. #9
    Super Member
    Window 7
    8 GB
    AutoCAD 2016
    Jun 2012
    USA
    530
    Quote Originally Posted by tzframpton View Post
    Thank you tzframpton and Remark, that's all i need to make sure.
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    Quote Originally Posted by Sengna View Post
    Attachment 48302 Need symbol to represent this type of pump?
    Use one similar to that which I posted an image of previously. Don't forget to show a motor too.
  1. VBA Electrical Single Line Diagram linked via excel
    By franchew in forum .NET, ObjectARX & VBA
    Last Post: 1st Jun 2015, 07:37 pm
  2. Centre Line for projection symbol
    By matt4 in forum AutoCAD Beginners' Area
    Last Post: 18th Jun 2009, 06:36 pm
  3. break-line symbol
    By cadmench in forum AutoCAD Beginners' Area
    Last Post: 12th Dec 2007, 06:40 pm
  4. Line length not correct after rotate
    By I_SUSSEX in forum AutoCAD Drawing Management & Output
    Last Post: 6th Dec 2007, 06:17 pm
  5. Correct symbol?
    By PeteUK in forum AutoCAD Drawing Management & Output
    Last Post: 5th Jan 2007, 09:43 am
Tags for this Thread
