Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    Full Member tipu_sultane's Avatar
    tipu_sultane's Computer Details
    Windows
    Not One
    Varies
    Either Desktop or Laptop
    Enough to Run AutoCAD
    Never Noticed
    Hard Disk
    USB
    LCD
    Electrical
    tipu_sultane's Discipline Details
    Electrical Engineer with specialization in Telecommunication
    Electrical
    Nomadic.
    AutoCAD 2012
    Apr 2014
    Rawalpindi, Punjab, Pakistan, Asia, Earth, Universe
    33
    Default Print CAD Drawing according to desire scale?
    I just want to print a CAD drawing according to some required scale. Please help me I have never done this before. I needs some hint.
    1:1
    1:2
    1:3
    1:4
    1:5
    1:10
    1:100
    Another thing what if I convert the drawing having specific scale into PDF format and print it. Are the scale remain same?
    If I scaled the diagram say in A4 paper then print this on A3 paper the scale remain the same?
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    To print a drawing from AutoCAD to a non-standard scale just choose Custom and input the desired report (in PRINT command dialog). Or if you use that often check the SCALELISTEDIT to add it to the default list.
    Regarding the preservation of scale when print a PDF from Adobe Acrobat Reader just choose the Page Sizing to Actual Size or None (depending of the version you use).
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Windows
    Not One
    Varies
    Never Noticed
    Hard Disk
    USB
    LCD
    Electrical
    Electrical
    Nomadic.
    AutoCAD 2012
    Apr 2014
    33
    In attached image you find the scale of diagram.
    That diagram I received in PDF format. I just print it on plotter by selecting the paper size A1 the scale is exactly accurate.
    But now I have got CAD file also. I just want to convert the exact diagram on A3 paper so that scales remains the same.
    I just confused. If I have diagram only on model then what to do and how to shift model into Layout and scale it as desired.
    By right clicking into the model I created the Layout but set scale from where (see figures).
    I want to test that. Please help.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,148
    I am not sure that you have grasped the concept of scales.
    If you have a drawing on an A1 sheet, then to shrink that drawing to fit on an A3 sheet, the scale of the drawing must have changed.
    Several guiding points that may be useful.
    Everything should be drawn to full scale in model space.
    Each layout should be printed at 1:1.
    Each viewport should be scaled to give the required scale of the output.
  5. #5
    Windows
    Not One
    Varies
    Never Noticed
    Hard Disk
    USB
    LCD
    Electrical
    Electrical
    Nomadic.
    AutoCAD 2012
    Apr 2014
    33
    I grasped concept of scale.
    I understand that if I print the diagram say have scale 1:5 in A1 size is larger then the same image printed on the paper say A3.
    But I am only asking about the procedure of printing on specific scale. From where start and from where ends.
    My simple question is if I use only plot command select a paper and specify the scale so the printer prints it or also needs to do some additional work like set units (Imperial, International etc).
  6. #6
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    eldon explained the procedure. Draw everything in model space at full size, switch to your layout, create a viewport, position your objects, assign it a scale and make sure you lock the viewport display so you do not inadvertently change it.. When done print the drawing and where it says "What to plot" make sure it says Layout (should be the default). Drawings are plotted at 1:1 scale meaning 1 mm = 1 unit. AutoCAD will automatically plot whatever is displayed in the viewport using the scale that was assigned.
    We assume you started your drawing using a metric template like acadiso.dwt and not the default imperial template named acad.dwt.
  7. #7
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,148
    A shortcut, that I have seen mentioned, is that an A1 drawing can be printed on an A3 at half the scale. This is the only one where it happens conveniently.
    The procedure is to make the custom scale to be 1mm = 2 units (edit the 1.966 figure to be 2 exactly).
    You will end up with the A1 shrunk by half, although the title block will still say that it is an A1 at 1 to 50, when it is on A3 paper at 1 to 100.
    Confused? It is easier to start at the beginning, before you take short cuts.
  8. #8
    Super Member
    Ski_Me's Computer Details
    DELL (why oh lord must I suffer)
    Electrical
    Ski_Me's Discipline Details
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    643
    His paper size is wrong if he wants to print to an A1 size. Currently he has A3 selected in the page manger box.
  9. #9
    Super Member
    Electrical
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    643
    Took a second closer look. Your entire layout is messed up. Wrong paper size, plot style missing, landscape instead of portrait, fit to paper is checked. I would just delete that layout and start a new one. Your main problem will be your title block. If your title block is drawn to fit an A3 size then you cannot not use it for an A1 because it wont fit unless you edit your title block to fit it. I think there's a couple of tutorials here somewhere that can help you with setting up a layout.
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    This should be interesting.
  1. Print to scale
    By danav in forum AutoCAD General
    Last Post: 12th Jul 2009, 05:36 pm
  2. print in scale
    By Kari in forum Revit General
    Last Post: 20th Mar 2009, 06:46 am
  3. Print Preview and Print does not equal Drawing
    By reggy in forum AutoCAD General
    Last Post: 19th Aug 2008, 03:53 am
  4. Replies: 1
    Last Post: 4th Dec 2007, 11:14 pm
  5. Replies: 10
    Last Post: 10th Apr 2007, 02:40 am
Tags for this Thread
