Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    Junior Member
    AutoCAD 2012
    Apr 2014
    12
    Default Title Block/Field Not Working as it Should
    Hi
    I'm new to the site so I'll try and be as clear as possible!
    I am creating a new title block for my office. In the new block I am using fields to limit the amount we have to fill it out. This has worked well with the exception of getting the viewport scale to work properly. I have visited just about every forum on the internet to see how to make this work and all i can discover is that I don't appear to be doing anything wrong.
    So my question is this.
    I am using a field in a title block that links to a viewport to give its custom scale value. ie the viewport is set at 1:100 then in the title block says that the scale shown in the drawing is 1:100. If I have to change the scale in the viewport to 1:50 then i can regen my layout and my title block will now say that the scale shown in the drawing is 1:50. Like Magic!!
    However this is not working for the scales 1:5, 1:25 & 1:200. Instead of the scale the field in the block just says "CUSTOM". Does anyone know why and how i can fix this? It makes no sense to me and works with all the other scales that we use.
    Thanks in advance
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    But does it work with all the other CUSTOM scales that you use?
    Junior Member
    AutoCAD 2012
    Apr 2014
    12
    yes but not those
    Junior Member
    AutoCAD 2012
    Apr 2014
    12
    we use 1:1, 1:2, 1:4, 1:5, 1:10, 1:20, 1:25, 1:50, 1:100 & 1:200 but the field does not work with 1:5, 1:25 & 1:200
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    I'd have to test it first to verify.
  6. #6
    Junior Member
    AutoCAD 2012
    Apr 2014
    12
    I have a drawing but i cant see how to up load it on here?
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Thanks but a drawing from you is not required.
    I think you should check the Format for your scale.
  8. #8
    Junior Member
    AutoCAD 2012
    Apr 2014
    12
    Sad to say but i've tried that already and i just get the same result.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    OK...under Property did you pick Custom Scale or Standard Scale?
  10. #10
    Junior Member
    AutoCAD 2012
    Apr 2014
    12
    i've tried both and get the same thing happening with each
  1. Attribute in title block exists in BLock Editor but not in Project.
    By Pawnsurfer in forum AutoCAD Drawing Management & Output
    Last Post: 19th Feb 2015, 09:10 pm
  2. link title of file to the title block inside
    By 19cruthik68 in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jun 2012, 09:25 am
  3. Replies: 0
    Last Post: 1st Mar 2012, 01:41 pm
  4. Custom Field in Title Block to display the Autodesk Product Name
    By tspoon in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Mar 2011, 08:31 pm
  5. Entered Text Field that will display the current Layout tab Title
    By Jadeous in forum AutoCAD Drawing Management & Output
    Last Post: 11th Mar 2009, 10:24 pm
Tags for this Thread
