Renlio Posted April 24, 2014 Share Posted April 24, 2014 autosnap marker comes on even when is turned off, but one slight difference is that the "marker" that shows up is a thinner marker. first photo shows the normal autosnap in use, second photo shows the snap comes on even when the snap function is switched off! this only happens when the background (map) is creative via coreldraw? any help on this would be much appreciated! Quote Link to comment Share on other sites More sharing options...
CADgirl Posted April 24, 2014 Share Posted April 24, 2014 Is 3D Object Snap turned on? Quote Link to comment Share on other sites More sharing options...
Renlio Posted April 24, 2014 Author Share Posted April 24, 2014 3D snap or any snap function is turned off. i have even went into Options and Drafting settings to turn the autosnap "maker" and "magnet" off but it doesnt seem to have any effect on it. the background i have produced was from a PDF then from CorelDraw i saved to the document as AutoCAD .dwg file. there is an option in saving the AutoCAD file as .dxf but would that be the problem? if saving in the .dxf would cure the problem then i will go down that route. i will give that a try! Quote Link to comment Share on other sites More sharing options...
nestly Posted April 25, 2014 Share Posted April 25, 2014 Are you certain the 2nd one is the AutoSnap marker and not the Aperture? What is you APBOX sysvar... 0 or 1? Quote Link to comment Share on other sites More sharing options...
Renlio Posted April 25, 2014 Author Share Posted April 25, 2014 yes, the 2nd one is not the Aperture, i have polyline function selected and when i go over the background it changes to AutoSnap marker. APBOX is at 0, i have alter between 0 and 1 but have no effect. Quote Link to comment Share on other sites More sharing options...
Renlio Posted April 25, 2014 Author Share Posted April 25, 2014 i have tried between .dwg and .dxf file and same issue still occurs. so i don't think the issue comes from how i extracted the background. Quote Link to comment Share on other sites More sharing options...
