Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 30
    Junior Member
    AutoCAD 2015
    Apr 2013
    15
    Default exploding blocks with 3d solids not behiving in autocad 2015
    i have just upgraded to cad 2015, and am encountering something i have not before experienced so figure there must be a variable somewhere i am unaware of.
    if i start with a block that contains both 2d objects and 3d solids that was for example made in a MM drawing.
    if i then insert it into a M drawing so that it is scaled down by 1000, if i explode that block any 3d solids will re-scale up by 1000, yet any 2d objects remain scaled down by 1000 (so are correct).
    in previous versions i have never run into this issue - solids in blocks that are exploded stay at the same scale as they were (stay scaled down by 1000)
    help appreciated.
    Junior Member
    AutoCAD 2015
    Apr 2013
    15
    In following up to this. if i try to manually scale the 3d solid down (scale factor 0.001)
    i get
    "Extremely small scale factor ignored.0.001"
    never had that problem before ?? i think the issues must be related.
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    *edit* Nevermind
    Confirmed that AutoCAD2015 will not allow scaling even simple 3D primitives down 0.001 X
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Looks like I'm going to shelve the 4th consecutive version of AutoCAD due to errors handling even simple 3D primitives...
    Full demo --> http://www.screencast.com/t/t969iMUrZR
  5. #5
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Damn, that doesn't look promising.
  6. #6
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Yeah, I was able to reproduce the OP's original problem, but in doing so discovered a way to reproduce the a problem where 3D object's geometry becomes disassociate with it's display, which has been a problem for several releases, I just couldn't reproduce it.
    I'm really disappointed as I had high hopes that 2015 would fix the problems that have me still using 2011 for ALL work related drawings.
  7. #7
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    That's interesting (i.e., disturbing).
    I've used each successive version 2011 - 2014, though, and have not encountered that anomaly. Just now, I tried to recreate (AutoCAD 2014) your screen capture events (Box, Conceptual VS, Scale, reScale, ...) but nothing was amiss.
    Can you post an example drawing?
  8. #8
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    The scaling problem doesn't exist in 2014 (and earlier) as far as I know, but the issue where 3D objects geometry become dis-associated with their display had been around since 2012. It just so happens that this new scaling problem in 2015 also causes the previous display issue.
    Here's a sample in ACAD2013 format, if you want to test in 2013-2014.
  9. #9
    AutoCAD 2013
    Nov 2011
    6,030
    I just tried scaling down a primitive cube in conceptual visual style on 2013, in an isometric view.
    I tried it using the regular 2D SCALE command, and 3D Modeling Error operation unsuccessful came up at the commandline,
    but I kept going and entered .001 as the scale factor and it did it.
    I then tried again with all the same variables using the 3DSCALE command and it did it without any
    disclaimers or warnings.
  10. #10
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Wow! AutoCAD has some transformation issues in it's closet.
    Bad enough to consider it only a display glitch, but if exported (AcisOut) and re-insert - the same or different file - the new geometry is set at that erroneous position.
  1. Exploding Blocks
    By jquackenbush in forum AutoCAD Drawing Management & Output
    Last Post: 2nd May 2012, 02:13 pm
  2. Exploding Blocks
    By kEVIN73 in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Jan 2008, 03:49 pm
  3. Exploding blocks
    By Rainy-Day in forum AutoCAD Drawing Management & Output
    Last Post: 4th Aug 2006, 10:40 pm
  4. Exploding Blocks
    By Ste1978 in forum AutoCAD Drawing Management & Output
    Last Post: 24th May 2006, 11:32 am
  5. 3Ds blocks and Multiview blocks exploding in viz render
    By Catch-22 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 17th Nov 2005, 07:33 pm
