Page 3 of 3 FirstFirst 1 2 3
Results 21 to 30 of 30
  1. #21
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Just installed 2015 and got to witness the whole sorted affair, start to finish. Pretty depressing.
    It appears that if the Scale command's error handler is in affect when the scale factor is input (the same error handler that creates the "Extremely small scale factor ignored." string), it corrupts the database. Not an irrevocable situation, apparently, but pretty troublesome if left unattended.
    Until Autodesk fixes the problem - Maybe the millimeter to Meter scaling effort can be "macro"fied to avoid the issue.
    ^C^C_Select;\_scale;p;;\;0.1;_scale;p;;@;0.1;_scal e;p;;@;0.1;
  2. #22
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    The "good" news is that I already got a phone call from Autodesk for the Support case I opened this morning (unfortunately I didn't take the call so I only heard it on voicemail). Basically they're aware and have confirmed the SCALE issue and have sent it up the line for further investigation and possible correction in future updates (no mention of the display issue which was also part of the support request) The "bad news" is that in my experience, being aware doesn't mean it will get fixed anytime soon, and sometimes "never" There's a chance it will be fixed in a hotfix otherwise the SP1 typically comes out in September so that's the first best chance... otherwise SP2 (if released) will likely be sometime in calendar year 2015...
  3. #23
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Fortunately, I have not seen a compelling reason for a hasty 2015 migration.
  4. #24
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Yep... for the price of your "upgrade" you're basically getting a new color scheme and a few new bugs. Honestly, I haven't seen much compelling in any of the recent releases. I could really use Drawing views as use the heck out of FLATSHOT, but I won't touch it because I've seen the havoc VIEWBASE "can" heap upon a model.
    BTW, got a call back... made sure they understood all the associated issues, and asked to have the case closed as long as the problems have been logged. I didn't expect one phone call, much less two, so I'll give them props for speedy customer service.
  5. #25
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Once again you have me puzzled re: havoc VIEWBASE can cause. Could you elaborate? Thanks.
  6. #26
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    If you watched the screencast I posted earlier, you will see how performing routine tasks in AutoCAD "can" cause 3D objects to become disjointed in such a way as to be displayed in a different location than their geometry. Creating "Drawing Views" using the VIEWBASE command is one of the tasks that "can" cause this issue with the geometry the views are associate with. I stated earlier in this thread the I've seen Viewbase cause the problem, and cautioned about potential problems with Viewbase in previous topics as well.
    To put this in context, I had a '94 Ford Explorer.... the one with the Firestone tires that failed causing many Explorers to flip/crash. I had 60,000 + miles on those tires and fortunately never had a failure. That doesn't make the problem any less serious, especially to those affected.
  7. #27
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    I was not implying anything; just asking for details. Thank you.
  8. #28
    Junior Member
    AutoCAD 2015
    Apr 2013
    15
    Quote Originally Posted by SEANT View Post
    maybe a lisp function to redefine the SC command that uses an if (or actually cond in the case below - should probably be an if) command to divide scale factors less than 0.1 by 0.1 a few times so as to be able to break the scale factor down into several 'scale' operations around a common base point.
    heres what i have so far - works for values up to 0.001, but to go further will need extra levels for each decimal point that the sale factor gets smaller
    cant believe we as users would have to wait for something so fundamental to the point of autocad for an issue like this to be fixed.
    Code:
    ;; scale by smaller than 0.1
        (defun c:sc (/ ss1 #sc #bp #sc2)
        (setq ss1 (ssget))
        (setq #bp (getpoint"\nEnter base point : "))
        (setq #sc (getreal "\nEnter scale factor : "))
    (cond
    ((>= #sc 0.1)(command "scale" ss1 "" #bp #sc))
    ((< #sc 0.1)(setq #sc2 (* #sc 10))(command "scale" ss1 "" #bp "0.1")(command "scale" ss1 "" #bp #sc2))
    (t nil)
    );end cond
    );end
  9. #29
    Junior Member
    AutoCAD 2015
    Apr 2013
    15
    line modified to allow for an extra decimal (so 0.0001)
    for every extra decimal wanted just increase the - (* #sc 100) and and an extra - (command "scale" ss1 "" #bp "0.1") - to the line.
    downside is for every action if you want to undo it, it is several 'undos' to get back to original size.
    Code:
    ((< #sc 0.1)(setq #sc2 (* #sc 100))(command "scale" ss1 "" #bp "0.1")(command "scale" ss1 "" #bp "0.1")(command "scale" ss1 "" #bp #sc2))
  10. #30
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Have you tried scaling the object down not with the SCALE command, but with the X,Y,Z scale in the Properties palette?
  1. Exploding Blocks
    By jquackenbush in forum AutoCAD Drawing Management & Output
    Last Post: 2nd May 2012, 02:13 pm
  2. Exploding Blocks
    By kEVIN73 in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Jan 2008, 03:49 pm
  3. Exploding blocks
    By Rainy-Day in forum AutoCAD Drawing Management & Output
    Last Post: 4th Aug 2006, 10:40 pm
  4. Exploding Blocks
    By Ste1978 in forum AutoCAD Drawing Management & Output
    Last Post: 24th May 2006, 11:32 am
  5. 3Ds blocks and Multiview blocks exploding in viz render
    By Catch-22 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 17th Nov 2005, 07:33 pm
