Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Full Member kArThIcK hAcKeR's Avatar
    kArThIcK hAcKeR's Computer Details
    Windows 7 Professional
    HP Compaq LE1911
    Intel Xeon
    8 GB
    nvidia
    Mechanical
    kArThIcK hAcKeR's Discipline Details
    Design Engineer
    Mechanical
    Design Engineer In L&T Ship-building
    AutoCAD 2014
    Jul 2013
    Chennai, India
    53
    AutoCAD Mass Convert DWG To DXF (Mas DWG Convert By Using Script Writer))
    Hi Guys,
    I Wanted To Mass Convert Some DWGs To DXFs,
    So, I looked Around and found some commercial softwares and also some lisp routine, but they didn't workout as i expected so i made a software (to interpret scripts).
    it works fine in converion of dxfs, so i thought this software might be usefull to some who want to mass convert dxfs,
    here is the software: AutoCAD Script Writer.zip
    This Software doesn't Require Installation, (It Runs Directly)
    ::REQUIREMENTS::
    1. AutoCAD which supports LISP routines (eG; full versions of AutoCAD 2010, But not AutoCAD LT Versions)
    ::Usage::
    1. In The "Location Of Files To Be Processed" Box, Paste The Location Where U have ur dwg files. (Default value is "D:\SomeFolder"). Dont Give A Root Location Such As "D:\" or "C:\" etc;
    2. In The "Command" Box, The Default Code Is Written For DXF Conversion, U can modify and write ur own Macros here, (If U know Acad Scripting Language)
    3. Pressing the "Create Script" Button will create a "Script.scr" file at the location of the dwg files
    4. Now Open AutoCAD, Now Press [Control]+[N] In AutoCAD, A New Window will be opened
    5. Now All U Have To Do Is Drag The "Script.scr", into the AutoCAD's Canvas (which is a blank black window usually)
    6. And thats it, autocad will start converting the DWGs to DXFs
    Thanks To Lee-Mac, dbroada & Bill-Tillman for giving me the answer and idea to my previous post,
    Don't Hesitate !!!
    Senior Member
    pmxcad's Computer Details
    win 10
    HP Z420
    xenon
    32G
    2x
    Electrical
    pmxcad's Discipline Details
    CAD designer in safety
    Electrical
    Safety (fire,access control, cctv, intercom, evacuation, fire panels)
    AutoCAD 2014
    Apr 2011
    Netherlands
    227
    You can use a script en use Scriptpro to run multiple drawings.
    It places the DXF in the drawing map.
    PmxCAD
    Script:
    FILEDIA
    0
    _SAVEAS
    DXF
    16
    FILEDIA
    1
    Forum Newbie
    Manufacture
    AutoCAD 2010
    Mar 2017
    1
    Excellent job buddy
    Got me out of a fix, may thanks.
    What was it created in/with?
    Forum Newbie
    P&ID
    AutoCAD 2014
    Jan 2017
    8
    hi Karthik,
    could you help me write code to convert DWG to PDF as I dont know how to write code
    Attachment 48653
    here is the software: Attachment 48630
    ::REQUIREMENTS::
    ::Usage::
    Thanks To Lee-Mac, dbroada & Bill-Tillman for giving me the answer and idea to my previous post,[/QUOTE]
  5. #5
    Forum Newbie
    Architectural
    AutoCAD 2018
    Oct 2017
    1
    Default Thanks
    I needed this to send some parts to our tube laser vendor. Worked perfectly. Thanks!
  6. #6
    Forum Newbie
    Mechanical
    AutoCAD 2017
    Mar 2018
    4
    Hello, I have 120 files in the folder, but it converts only the first file. Please help me
  7. #7
    HP Compaq LE1911
    Intel Xeon
    8 GB
    nvidia
    Mechanical
    Design Engineer
    Mechanical
    AutoCAD 2014
    Jul 2013
    Chennai, India
    53
    Quote Originally Posted by iridium View Post
    Oooh i'm back after a long time (o_O)
    Can you post the return script that you had received (Script.scr), so that i can see what the issue is?
    Don't Hesitate !!!
  8. #8
    Forum Newbie
    Mechanical
    AutoCAD 2017
    Mar 2018
    4
    Quote Originally Posted by kArThIcK hAcKeR View Post
    Hi!
    Here is the script.
    Thanks for help!
  9. #9
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,511
    The obvious you dont need to delcare as a defun just run command or load the defun once into acaddoc.lsp then just call the defun (dxfout)
    A couple of suggestions in scripts the / \ can make the difference
    Check make a test directory the 200.239 to 200_239 the . may be the problem
    Code:
    _.OPEN "D:\\123\\200.239_47.dwg" mspace (command "_.dxfout "" "16" "_.regen" "_.close" "_Y")
    or
    _.OPEN "D:\\123\\200.240_16.dwg" mspace (TODXF)
  10. #10
    HP Compaq LE1911
    Intel Xeon
    8 GB
    nvidia
    Mechanical
    Design Engineer
    Mechanical
    AutoCAD 2014
    Jul 2013
    Chennai, India
    53
    Hi!
    Here is the script.
    Thanks for help!
    Hi iridium, as Bigal suggested in the post above the "." (dot) in the file name is what's causing the problem..
    If you have a file mass file renamer (suggestion: "Bulk Rename Utility"), try renaming the files from 222.123 to 222_123.
    Let me know if it worked..
    Don't Hesitate !!!
  1. How can I convert dxf to dwg in batch??
    By Han_BFY in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Apr 2016, 03:48 am
  2. Mass convert dwg to dxf
    By kArThIcK hAcKeR in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd May 2014, 11:23 am
  3. Batch convert idw or dwg's to pdf's
    By andar424 in forum Autodesk Inventor
    Last Post: 27th Apr 2013, 04:32 am
  4. Batch Convert DWG to RFA
    By Trevit in forum Revit General
    Last Post: 25th Jun 2012, 10:44 pm
  5. Mass convert 2006 dwg's to 2000 format.
    By HoustonPhotog in forum AutoCAD Drawing Management & Output
    Last Post: 21st Apr 2006, 02:45 pm
Tags for this Thread
