Results 1 to 8 of 8
    Junior Member
    AutoCAD 2012
    May 2014
    12
    Default Printing an AutoCAD 2012 drawing in Word- -Prints thumbnail size only
    I am new to AutCAD 2012 and I am writing a visual math book. I have had great success with my drawings. I am trying to post some of my drawings to a teachers online site. I have to copy my drawings in to Microsoft Office Word 2007 which I am able to do. The problem arises when I go to print, it will only print out a thumbnail size of my drawing.
    Can anyone help
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,096
    If you go to the Application Button > Export > Other Formats, choose "Metafile (*.wmf)" in the Files of Type drop-down menu. It will then prompt you to select the objects you wish to be contained in the image export.
    A Windows Metafile is vector-based, and it is compatible with all Microsoft products such as Word. With it being a vector graphic it will maintain the highest quality of resolution as you rescale the image to fit your format.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Junior Member
    AutoCAD 2012
    May 2014
    12
    Default Printing an AutoCAD 2012 drawing in Word - Prints thumbnail size only
    Thank you,
    Still learning. That makes sense
    Quote Originally Posted by tzframpton View Post
    Junior Member
    AutoCAD 2012
    May 2014
    12
    Default Printing an AutoCad 2012 drawing in Word - Prints thumbnail size only
    Hi again,
    I tried using "metafile" (*.wmf). It showed up fine in Word, but when I went to print it printed as a thumbnail size again.
    Any suggestions?
    KC
    Quote Originally Posted by kcfirtel View Post
    Thank you,
  5. #5
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,118
    How are you inserting the image into Word?
    Are you using "Insert - Picture - From File", or something else?
  6. #6
    Junior Member
    AutoCAD 2012
    May 2014
    12
    Default Printing an AutoCAD 2012 in Word - Prints thumbnail size only
    Hi Eldon,
    In a "Metafile (*.wmf)" file , when it prompts me to select image, I just copy the image. I then go to my Word document and paste in drawing. It appears the correct size on screen, but when I print or view as print preview, it is thumbnail size.
    Thank you
    KC
  7. #7
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,118
    I am afraid that the first part of your procedure has got me baffled. When you get the image into the document, can you re-size the image?
    The way I do it is to have the Word document open, and then "Insert" a picture using the .wmf file directly, which would seem a less complicated way of doing things, with no clipboard involved. The picture is then able to be sized, moved and can also be cropped.
  8. #8
    Junior Member
    AutoCAD 2012
    May 2014
    12
    Thank you for your help.
    I got it to work.
    I've been told that I like to do things the hard way and I guess that this was a fine example.
    Thanks again
  1. Printing from Autocad LT 2012
    By AbdulQ in forum AutoCAD Beginners' Area
    Last Post: 14th Jun 2012, 05:39 pm
  2. Batch printing prints getting out of order
    By SunnyTurtle in forum AutoCAD General
    Last Post: 23rd Sep 2011, 02:37 pm
  3. Drawing scale printing wrong size on paper
    By caduseless in forum AutoCAD Beginners' Area
    Last Post: 6th Jan 2010, 06:38 pm
  4. MS Word/AutoCAD Text Size Query
    By happyunited in forum AutoCAD General
    Last Post: 11th Nov 2009, 05:38 pm
  5. Printing Word Doc in Autocad Probs
    By Simple153 in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Dec 2006, 05:06 pm
