Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2013
    May 2014
    2
    Default CAD 2013 printing
    Guys, please i need help, i use autocad 2013 and i cant print on A3, printer type; HP Officejet 7500A wide format (E910). i tried to import a pc3 file into my version 2013 which i saved from a version 2010, but never worked. i see all paper sizes except A3.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    The factory specs say it supports A3: 297 x 420 mm (11.7 x 16.5 inches), and A3+.
    Maybe you need to download the latest printer driver for it from HP. The **.pc3 files don't control the paper sizes available, the printer driver tells the .pc3 file what to remember about the printer, like available paper sizes.
    You also might try removing and re-installing the printer. There shouldn't even be a .pc3 for the HP in the dropdown list of printers, simply an entry for the printer for you to select. (it really is a .pc3 file, but not labeled as such.)
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    You can usually add the paper sizes by using Properties button beside where the Plotter is listed in the Plot Manager of AutoCAD, then choose Custom Properties.
    Forum Newbie
    AutoCAD 2013
    May 2014
    2
    thanks Dana i am trying to do that, give you a feed when i do so, thanks again
  1. Mavericks Support for AutoCAD 2013 for Mac LT 2013 for Mac
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 16th Nov 2013, 06:50 pm
  2. Product Update 6 for Autodesk 3ds Max 2013 & 3ds Max Design 2013
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 19th Nov 2012, 08:40 pm
  3. Conceptual Printing Autocad 2013 problems
    By garethpoile in forum AutoCAD Drawing Management & Output
    Last Post: 31st Oct 2012, 11:55 am
  4. Graphic card update for Inventor 2013 and AutoCAD 2013
    By Alexger in forum Autodesk Inventor
    Last Post: 27th Sep 2012, 12:01 am
  5. Problem with second monitor -AutoCAD 2013 and Inventor 2013
    By Alexger in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th Sep 2012, 02:41 pm
