gotchy Posted May 6, 2014 Share Posted May 6, 2014 I am hoping that someone here is knowlegeable in the Sheet Metal mode of Solidworks. For some reason I am geting a curl instead of a straight bend. I did get one side to work allright, the problem is that I don't know why. I enclose three images, with one being the flat blank that I start with. Thank you, gotchy Quote Link to comment Share on other sites More sharing options...
Dana W Posted May 6, 2014 Share Posted May 6, 2014 I don't know solidworks, but it appears there is no end point for that bend, and there is a "line" where the bend ends at the other two tangs. the program may be bending until it hits a limit, which looks to me like the end of the little tang. What made a line appear at the 90 deg point under the big whatzits? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 7, 2014 Share Posted May 7, 2014 Why are you starting with a flat blank? That is the reverse of how to use sheet metal in SolidWorks. The design intent is the finished part. Model the finished part - SolidWorks will give you the flat pattern. Quote Link to comment Share on other sites More sharing options...
