Results 1 to 2 of 2
    Forum Newbie
    AutoCAD 2010
    May 2014
    3
    Default When inserting vertex in pline, jump to the new vertex
    Hi everyone,
    I guess I messed up some strange option in AutoCAD here. For my job, I often need to add a number of vertices to a 2D Polyline / edit polylines.
    Until a couple of days ago, when inserting a new vertex to a polyline, it automatically jumped to the new vertex, so I would add a number of vertices by only using the <i> (insert) command.
    But now, when inserting a new vertex in a polyline, the X stays on the original vertex, the vertex selected before inserting the new one. So when inserting a number of vertices, I have to press <i>, then <n> (next) for every vertex inserted. The way vertices get inserted now is as if you insert a vertex by pressing <i>, then press <p> for previous so the X jumps back to the original. I'd like to insert a couple of vertices without pressing <n> each time!
    I have tried to find this option but couldn't find it anywhere. (pline options? Pedit options?) I am using AutoCAD 2010, no mouse commands (only keyboard). Hope someone can help me out here, thx in advance!
    EDIT: English + more thorough explanaition...
    Forum Newbie
    AutoCAD 2010
    May 2014
    3
    SOLVED!! Finally...
    My Plinetype setting was set to 0 - I was drawing '2D polylines' instead of 'regular' polylines. Apparently these have different pedit methods, as described above.
    Damn you Feature Creepy AutoCAD.
  1. how to add vertex in to polyline
    By 121madhu in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Oct 2013, 08:26 am
  2. Replies: 17
    Last Post: 6th Apr 2012, 07:57 pm
  3. Lwpolyline Length (Vertex to vertex)
    By srinivasarajug in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Jan 2012, 12:05 pm
  4. pline, length of vertex distance from ends?
    By orange in forum AutoCAD General
    Last Post: 16th Nov 2010, 03:06 am
  5. Add Vertex
    By hicap in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Jun 2009, 11:58 am
Tags for this Thread
