DieterBvH Posted May 7, 2014 Share Posted May 7, 2014 (edited) Hi everyone, I guess I messed up some strange option in AutoCAD here. For my job, I often need to add a number of vertices to a 2D Polyline / edit polylines. Until a couple of days ago, when inserting a new vertex to a polyline, it automatically jumped to the new vertex, so I would add a number of vertices by only using the (insert) command. But now, when inserting a new vertex in a polyline, the X stays on the original vertex, the vertex selected before inserting the new one. So when inserting a number of vertices, I have to press , then (next) for every vertex inserted. The way vertices get inserted now is as if you insert a vertex by pressing , then press for previous so the X jumps back to the original. I'd like to insert a couple of vertices without pressing each time! I have tried to find this option but couldn't find it anywhere. (pline options? Pedit options?) I am using AutoCAD 2010, no mouse commands (only keyboard). Hope someone can help me out here, thx in advance! EDIT: English + more thorough explanaition... Edited May 7, 2014 by DieterBvH Quote Link to comment Share on other sites More sharing options...
DieterBvH Posted May 15, 2014 Author Share Posted May 15, 2014 SOLVED!! Finally... My Plinetype setting was set to 0 - I was drawing '2D polylines' instead of 'regular' polylines. Apparently these have different pedit methods, as described above. Damn you Feature Creepy AutoCAD. Quote Link to comment Share on other sites More sharing options...
