Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2014
    May 2014
    2
    Default Autocad 2014 centering viewports?
    Hey guys,
    It has been years since I have touched AutoCAD and I am creating a small drawing for work, i have a question about view ports in layouts looking into models.
    So basically, if i have a drawing of a car, id want a viewport in my paperspace layout to focus on a wheel.
    how can i get a paperspace viewport to center on the wheel from my model space?
    I have tried changing the geometry options in the viewports properties, but that focuses on its position in the paperspace layout?
    AutoCAD 2013
    Nov 2011
    6,051
    Welcome back, and to CADTutor.
    Go to your Paperspace and click twice inside of an UNLOCKED viewport.
    Once you have done that your cursor is actually in MODELSPACE, although you still see
    a white paperspace type background.
    Now you are free to zoom around and change your viewport scale with the scroll wheel on your mouse.
    If you hold down the scrollwheel on the mouse, you will be able to PAN the view inside the viewport,
    and thus position and size it as you want it to appear in your viewport. Set up your viewport view,
    then LOCK your viewport scale, so that the view will not be subject to further change, unless unlocked.
    You will see the little PADLOCK icon in the lower right quadrant of your screen, which will lock your viewport scale and view.
    There are other options as well, such as setting a different VISUALSTYLE in a viewport, and VIEWPORT FREEZING
    any layers which you might not want to be visible in that particular viewport.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Quote Originally Posted by serpentxx View Post
    The Center option of the ZOOM command is what you are looking for, "Z", [space], "C", [space], on your keyboard.
    Drafting is a breeze.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,769
    Quote Originally Posted by RobDraw View Post
    Zoom Window, Zooom Center.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  5. #5
    Forum Newbie
    AutoCAD 2014
    May 2014
    2
    Thank you all for the replies,
    That is exactly what I needed to do
  1. AutoCAD 2014 Plotting layout w/3D viewports
    By Dinochrome in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Mar 2014, 06:33 pm
  2. Replies: 5
    Last Post: 4th Mar 2014, 05:07 pm
  3. Moving from AutoCAD 2002 to AutoCAD 2014...block issues
    By spaulus in forum AutoCAD Beginners' Area
    Last Post: 17th Feb 2014, 12:56 pm
  4. AutoCAD 2014 & Revit 2014 Free Book Titles Released
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 31st May 2013, 08:20 pm
  5. AutoCAD 2014 & AutoCAD LT 2014 Preview Guides
    Last Post: 28th Mar 2013, 07:10 pm
Tags for this Thread
