Results 1 to 3 of 3
    Forum Newbie
    arkitectin's Computer Details
    Windows 7
    Facilities Mgmt
    arkitectin's Discipline Details
    Project Manager, Healthcare
    Facilities Mgmt
    AutoCAD 2014
    May 2014
    Southern Illinois
    2
    Default Data Extraction to Excel turns data into dates.
    Hello Everyone,
    I'm using AutoCad 2014 and have Microsoft office 2007. I use attributes in every drawing. Most have identifications as 1-01 which stands for Floor 1-Item #01 or 3-27 which stands for Floor 3-Item#27. When I use the data extraction, I extract it to the drawing, everything is correct at this point. Then export to a CSV file. If I open the CSV file in Excel all of my attributes turn into dates 1-Jan or 27-Mar. If I try to turn the column back to general or text it becomes some 5 digit number. Is there a way to export the data into excel but it keep the formating of the data in Cad?
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,165
    Format your excel cells as text before you import the data, or if you use the excel import data wizard the third screen gives you the chance to select the type of data for each column (choose text).
    Forum Newbie
    Windows 7
    Facilities Mgmt
    Facilities Mgmt
    AutoCAD 2014
    May 2014
    Southern Illinois
    2
    In CAD the columns were previously set to text which is why I couldn't figure out why they were becoming dates in excel.
    I redid the data extraction. On Page 5 of 8, I right clicked on each column, selected Set Column Data Format and changed them all to General. On Page 6 of 8, I selected to Insert data and to Output data. Instead of trying to export the table from CAD to excel, I opened the Output Data file created in excel directly. It opened and all of my data was correct, it had not converted to dates.
    Thanks for your help!
  1. Replies: 2
    Last Post: 22nd Apr 2012, 07:13 am
  2. Autocad 2010, data extraction to excel
    By Lagviper in forum AutoCAD Beginners' Area
    Last Post: 21st Sep 2011, 11:33 pm
  3. Replies: 5
    Last Post: 1st Mar 2011, 02:55 pm
  4. Replies: 2
    Last Post: 5th Jan 2011, 09:40 pm
  5. Data Extraction to Excel table problem
    By JBullseye74 in forum AutoCAD Drawing Management & Output
    Last Post: 20th Nov 2009, 12:51 pm
Tags for this Thread
