Results 1 to 7 of 7
    Forum Newbie
    AutoCAD 2014
    May 2014
    2
    AutoCAD Viewport Scales are too big
    I'm running AutoCAD 2014 on a Macbook pro but I've had this problem when I was running 2012 on the same laptop.
    I've done my drawing in model space in millimetres, but when I try to set a viewport in paperspace at any scale it zooms the drawing in way bigger than the scale should be.
    I've checked that the paper is the size I thought it was etc. I found out that AutoCAD was setting my insertion units and paper units to inches automatically, but when I created a new file to change them both to mm I still have the same problem. The scales don't seem to have any relation to the actual scale they should be (eg 10x bigger)
    Any ideas would be much appreciated!
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    Welcome to CADTutor.
    If you're using the ZOOM Command through an activated Viewport, then ensure that your scale ratio entry is in this format: 1/20XP (lower case "xp" is fine).
    Otherwise, simply select the inactive Viewport from PaperSpace, and change the Annotation Scale, which has a one-way relationship with the Standard Scale setting (i.e., changing Standard Scale in Properties Pane, or via ZOOM Command as noted above, does not change Annotation Scale).
    Cheers
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
    AutoCAD 2013
    Nov 2011
    6,056
    What template are you starting your drawing from? The default one will be an Imperial based .dwt file.
    Try using one of the templates, the name of which ends with ISO, as they are metric.
    Click on the big A up in the left hand corner, and select NEW, DRAWING and you will be linked to the template dialog box,
    where you can specify what template you want to use to create your new drawing.
    That will probably help you.
    If you typically draw in metric units, then you should go to OPTIONS, on the FILES tab
    open the TEMPLATE SETTINGS link, then reset the Default QNEW Drawing template to one of the metric ones.
    In that way, when you press the QNEW icon, the metric template which you have specified will be used.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    Let's cut to the chase shall we?
    Attach a copy of the DWG file to your next post. Someone here will take a look at it.
  5. #5
    Forum Newbie
    AutoCAD 2014
    May 2014
    2
    Thanks for the replies!
    I opened a new drawing from an ISO template and my viewports are at the right scale now
    I tried fiddling around with my old drawing to convert it to mm (I think I must have drawn it in inches) but in the end I just decided to redraw it on a metric template.
    I also set my default template to be metric. For anyone interested, to do this on a mac you go to AutoCAD 2014 > Preferences > Application > Template Settings > Default Template File Name for QNEW
    Thanks for the help
  6. #6
    AutoCAD 2013
    Nov 2011
    6,056
    Quote Originally Posted by roudini View Post
    Thanks for the help
    Congratulations, glad you got it sorted out, and have set a personally appropriate default template for regular use.
    In the future, should you need to change a drawing which has been done in errant units, there is a way, at least on a PC.
    I am not sure if you will have this option on a MAC version of the software.
    The command you would use on a PC is -dwgunits , be sure to include the hyphen.
    Read the commandline prompts carefully, and you will be lead through the process
    of rectifying the drawing units and it will also rescale whatever needs rescaling.
    You should probably make a copy of a drawing, and experiment with the command on it,
    and put it throught the paces. If you still have your old one, try using it, as it is now expendable.
  7. #7
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Thanks for the help
    It wasn't the scale that was too big. 1000 inches is waaaaaaaaaay longer than 1000 mm, or even 1000 cm for that matter.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  1. Purging Viewport Scales
    By CAD123 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Jun 2011, 01:07 pm
  2. Viewport scales
    By Burke85 in forum AutoCAD General
    Last Post: 7th Apr 2011, 10:38 pm
  3. Viewport scales
    By lauriemck in forum AutoCAD Beginners' Area
    Last Post: 23rd Nov 2009, 04:26 pm
  4. Viewport scales
    By guyzen2004 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Nov 2008, 12:15 pm
  5. Drawing scales & viewport scales
    By manhattan in forum AutoCAD General
    Last Post: 4th Aug 2008, 08:53 pm
