Results 1 to 10 of 10
    Senior Member ROBP's Avatar
    ROBP's Computer Details
    WINDOWS 10 PRO
    Eurocom
    IINTEL i7-6700K- 4.00GHz
    64 GB
    K5100M
    1 TB
    1 TB
    N/A
    P&ID
    ROBP's Discipline Details
    Powerhouse designer
    P&ID
    MEP 2018
    Oct 2013
    Montreal, Canada
    344
    Default Dynamic Block circle stretch
    I have a block with visibility option but i need to be able to stretch one of the inner circle to match a few fixed dimensions i am sure it can be done with a lookup table but after a few trial and error i don't seem to be able to achieve it.
    Offset is an option i can probably add in the authoring palette by copying a command and changing the action related to it but will it work , if it does i am still back to square one i need to set values for that circle and be able to choose it so that the circle will follow the preset dimensions, can anyone of you help?
    Best,
    R
    P.S. file can be sent to be able to see the flavor and test it
    Creativity is intelligence having fun
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,115
    Try using scale, and if you intend using odd sizes I would suggest using a starting circle of 1 or 10 or 100 units, just to make the other values easier to work out.
    WINDOWS 10 PRO
    Eurocom
    64 GB
    K5100M
    1 TB
    1 TB
    N/A
    P&ID
    Powerhouse designer
    P&ID
    MEP 2018
    Oct 2013
    Montreal, Canada
    344
    Quote Originally Posted by steven-g View Post
    For some unknown reason it does not work i must be doing something wrong dang
    Reminder the values are fixed ones (pipe wall thicknesses) and it must have a lookup for me to choose from from a drop down menu.
    Maybe i should send the file for review at least get one started and i will add the rest?
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,115
    This is just the 2 circles, the two linear parameters are linked to keep the wall thickness constant. Post the block you are working on if you have any problems
  5. #5
    WINDOWS 10 PRO
    Eurocom
    64 GB
    K5100M
    1 TB
    1 TB
    N/A
    P&ID
    Powerhouse designer
    P&ID
    MEP 2018
    Oct 2013
    Montreal, Canada
    344
    Please find the annotated file explaining the needs.
  6. #6
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,115
    Example attached.
  7. #7
    WINDOWS 10 PRO
    Eurocom
    64 GB
    K5100M
    1 TB
    1 TB
    N/A
    P&ID
    Powerhouse designer
    P&ID
    MEP 2018
    Oct 2013
    Montreal, Canada
    344
    Example attached.
    Yes that does it and exactly what i needed
    Thanks a million
    Best
    R
  8. #8
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,115
    You're welcome
  9. #9
    WINDOWS 10 PRO
    Eurocom
    64 GB
    K5100M
    1 TB
    1 TB
    N/A
    P&ID
    Powerhouse designer
    P&ID
    MEP 2018
    Oct 2013
    Montreal, Canada
    344
    You're welcome
    Final product
  10. #10
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,115
    Nice I bet that kept you busy for a while
  1. Dynamic Block Stretch
    By CiCAD in forum AutoCAD General
    Last Post: 7th Dec 2010, 08:18 pm
  2. Dynamic block stretch
    By michelvh in forum AutoCAD Drawing Management & Output
    Last Post: 20th Feb 2009, 10:43 pm
  3. Dynamic block stretch
    By tlawson in forum AutoCAD General
    Last Post: 29th Oct 2008, 02:39 pm
  4. 2-D stretch in a dynamic block?
    By specialforces27 in forum AutoCAD Drawing Management & Output
    Last Post: 25th Jun 2008, 03:47 pm
  5. dynamic block stretch - help please!
    By urbanista in forum AutoCAD Drawing Management & Output
    Last Post: 6th Sep 2007, 01:33 pm
