Results 1 to 4 of 4
Thread: Layer trouble
    Forum Newbie
    AutoCAD 2012
    May 2014
    2
    Default Layer trouble
    would anyone know why a layer wouldn't be showing up? i've got the layer both switched on on my view port and on the model space, it's also not frozen. it's showing on the model space but not on the paper space?
    help would be appreciated!
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    It is probably frozen for that viewport, so go into that viewport, start the layer manager, now look to the right for the VP Freeze column (you may have to scroll over some), finally look for your layer and thaw that layer.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Is the layer frozen in the viewport? What kind of objects are on that layer?
    Drafting is a breeze.
    Forum Newbie
    AutoCAD 2012
    May 2014
    2
    thanks rkent, it was a layer that i had frozen earlier and couldn't see when i scrolled through! after some careful inspection i've found it!
  1. Layer isolation trouble
    By lh2os in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 7th Aug 2013, 06:33 pm
  2. trouble deleting a layer & drawing oddity
    By humpo in forum AutoCAD General
    Last Post: 10th May 2013, 02:01 am
  3. Layer Director trouble
    By woodman78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th May 2011, 05:18 pm
  4. Trouble Changing Layer Color
    By gsksun4 in forum AutoCAD Beginners' Area
    Last Post: 24th Feb 2010, 10:39 pm
  5. the layer trouble
    By cowcowkiller in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Jun 2009, 11:29 am
Tags for this Thread
