Results 1 to 10 of 10
    Forum Newbie
    AutoCAD 2013
    Apr 2014
    9
    Default Dimensions in dynamic blocks
    I trying to make a dynamic block which includes linear dimensions.
    Sometimes the dimensions are deleted completely, when I try to hide them in a visual state.
    Other times the dimensions are visible in all states, even though it should only be visible in one state.
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,159
    It should work OK, can you post a block, someone can try and see what is happening.
    Forum Newbie
    AutoCAD 2013
    Apr 2014
    9
    Sure, here it is.
    The dimensions I am having trouble with is the ones in the bottom.
    The one on the side works like it should.
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    Windows 7 Professional
    Dell
    Intel Xeon E5-1603@2,80GHz
    4GB
    NVIDA Quadro K600
    DELL 23" & SAMSUNG 21"
    not applicable
    Nov 2005
    Kenley, Surrey, UK
    5,644
    I think they are there, but tiny. I assume its to do with annotation scale but as I never use them I can't comment further.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    "Everything in drafting is logical. Except what isn’t." - Gavin Guile. (from the Lightbringer series of books by Brent Weeks)
    Dave
  5. #5
    Forum Newbie
    AutoCAD 2013
    Apr 2014
    9
    Sorry, I posted the wrong drawing.
  6. #6
    Dell
    4GB
    NVIDA Quadro K600
    not applicable
    Nov 2005
    Kenley, Surrey, UK
    5,644
    are you sure that one is correct? The dimensions don't appear to be connected to anything.
    Dave
  7. #7
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,159
    You have used different parameters and different geometry in each visibility state, you also need to add different dimensions associated with each size, at the moment when you switch visibility state the dims lose the geometry they are associated with.
    EDIT
    The first dwg looks to work fine here, how where you getting it to break down?
  8. #8
    Super Member resullins's Avatar
    resullins's Computer Details
    Windows 10
    Dell Precision T5500
    Intel Xeon E5405
    12.00 GB
    NVidia Quadro FX 4500
    Dual Dell 20" 16x9 running DVI-D
    AutoCAD 2017
    Feb 2011
    Nashville, TN
    675
    I agree with what Steven said. You've got dimensions that aren't connected to your visibility states properly.
    I don't think he was having trouble with the first dwg, which is why he posted the second one. There are no VS in that one... so that would make sense that it would work.
  9. #9
    Forum Newbie
    AutoCAD 2013
    Apr 2014
    9
    Thanks. It seemed odd though. I made the dimension and when I tried to hide it for a VS it sometimes was deleted and other times kept being visible in all states.
    The I saved the drawing and closed it, opened it again and then I could hide it in the vs I wanted, without it being deleted or visible in all states.
  10. #10
    Windows 10
    Intel Xeon E5405
    12.00 GB
    AutoCAD 2017
    Feb 2011
    Nashville, TN
    675
    That sounds like an AC glitch to me... not a problem with your block.
  1. Help me, create dimensions with Dynamic Blocks visible
    By minhphuong_humg in forum AutoCAD Drawing Management & Output
    Last Post: 25th Jan 2014, 06:51 am
  2. Please, help me extract data Dynamic Blocks and Attribute blocks to Excel
    By minhphuong_humg in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jan 2014, 05:37 pm
  3. Insert dynamic block from file with multiple dynamic blocks
    By BUrBaKy in forum AutoCAD Drawing Management & Output
    Last Post: 14th Nov 2012, 11:38 pm
  4. Replace Dynamic Blocks with Normal Blocks based on Parameters
    By LeighJ in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 2nd Aug 2012, 10:33 am
  5. Replies: 5
    Last Post: 26th Jun 2009, 04:50 pm
