Faouweb Posted May 14, 2014 Share Posted May 14, 2014 Hi, I want to know how to use a small assembly by using Sketch Block. Until now it OK but when I put the last Constraint , in my case Concentric Constraint, my Sketch is Fully Constraint and can not rotate circle block, and I have a Flexible part that does not want to follow the direction. More détails in the picture and the file. I use Inventor 2013. What I am doing wrong? Thank you SKETCH.ipt Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 14, 2014 Share Posted May 14, 2014 Show all constraints. You have a perpendicular constraint that doesn't make sense. Explode the connecting rod block and set the distance before turning it into a block. Quote Link to comment Share on other sites More sharing options...
Faouweb Posted May 14, 2014 Author Share Posted May 14, 2014 Thank you JD Mather for you help, I did a big mistake we can't have 2 different diameter and link them like I did in the drawing. Now I will try something a little bit more complicate to learn Quote Link to comment Share on other sites More sharing options...
