Results 1 to 3 of 3
    Junior Member Dan's Avatar
    AutoCAD 2006
    Mar 2006
    UK
    20
    Default Copy layers/dimstyles/text styles between drawings
    Hi,
    Another adt2006 question (setting up templates at work and want to get it right!)
    Is there a quicker way of transfering layers/dimstyles etc between drawings rather than using the content browser and dropping them in? Am currently making a set of templates for the office and know things will kick off as soon as they go live, so i want a quick way of spreading changes across the suite of drawings.
    e.g. someone requests a new dim style which then has to be copied to all the template dwgs.
    A kind of 'copy all dimstyles/layers/text style/linetypes to project dwgs.' command!
    If this has not been done already, is it possible using lisp or would it just become so complex and convulted that it would be better doing it via content browser?
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,495
    Oh it's definitely possible using LISP.... i wouldn't know how to help ya there because my LISP programming is minimal.
    also, save everything as a block, and INSERT the block with everything already done. :-)
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
    AutoCAD 2006
    Mar 2006
    UK
    20
    Using a block is a smart little fix for the time being - thanks!
