Grant Posted May 15, 2014 Share Posted May 15, 2014 Found this a problem with Acad 2015 - if you get this error go into your code and look for 'mapcar' then within that look for 'command' and change to 'command-s' (if plst (progn (mapcar '(lambda (X) ;turn layer on (if (> (cadr X) 0) (command-s "._-LAYER" "_ON" (car X) "") );i );l plst );m );p Hope this helps some people as it was hard to find Quote Link to comment Share on other sites More sharing options...
Grant Posted May 15, 2014 Author Share Posted May 15, 2014 As always there is more to it see: http://docs.autodesk.com/ACDMAC/2014/ENU/index.html?url=files/GUID-5C9DC003-3DD2-4770-95E7-7E19A4EE19A1.htm,topicNumber=d30e351208 and http://knowledge.autodesk.com/support/autocad-mep/troubleshooting/caas/discussion/t5/Visual-LISP-AutoLISP-and-General/Lisp-Problems-in-2015/td-p/4992168.html Quote Link to comment Share on other sites More sharing options...
