Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Super Member lamensterms's Avatar
    lamensterms's Computer Details
    Windows 7 - 64bit
    Manufacture
    lamensterms's Discipline Details
    Steel Detailer
    Manufacture
    3D Modelling - Mechanical & Structural 2D Detailing - Shop Drawings
    AutoCAD 2014
    May 2011
    Berwick, VIC, Australia
    569
    Default Finding and Sorting Drawings... How do you do it?
    Hey guys,
    Just wanted to start a discussion on peoples various methods of managing their drawing libraries. Specifically - if you have a list of drawings which you need to collect, how do you isolate them from your drawing library?
    For example, as a steel detailer, we use ProSteel - which produces individual .DWGs for each part and group in our models, so we often work on jobs with 1000+ drawings. Often we are asked to provide a batch of drawings for only a certain area of the job. It is quite easy to isolate the required elements in the model, and produce a list of the drawings pertaining to this area... but actually collection these drawings from the list can be quite tricky (especially if using only Windows Explorer).
    So... my question to you guys is - how do/would you do it?
    Looking forward to hearing some ideas.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Maybe grid points over entire site export out to say excel as you create layouts, use the window to search for grid pts, grid + dwg number. When searching remove duplicates from list produced for an area.
    1000,1000 dwg1
    1100,1000 dwg1
    1200,1000 dwg1
    1300,1000 dwg2
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    All of our drawings, whether produced in-house or obtained from outside sources, are logged into a master database. We create unique queries to cull out the drawings we are interested in finding. So a query might be based on a process code (ex. - 02_1), a company name (ex. - Fairfield County Sprinkler) or a drawing type (site plan). Some queries are utilized so often (ex. - P&ID) that they are a standard part of the database while others may be used only once then not used again.
    Windows 7 - 64bit
    Manufacture
    Steel Detailer
    Manufacture
    AutoCAD 2014
    May 2011
    569
    Thanks for the replies guys.
    BigAl, do you mean number the drawings by area (each area has a specific number/code)? That is a good idea.
    ReMark, what is the software that you use for your database? Do you attach tag/key words/letters to the drawings to find them?
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    The database was created in MS Access. To view CAD drawings and PDFs the engineers utilize our internal engineering website where the appropriate links can be found.
  6. #6
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Like Remark we have a database based on MS access for recording the master project details, but our drawings rarely go into big numbers 4-5 max. Though I am working on one with 86 layouts. Just use dwgindex to jump to correct layout.
    I was suggesting above a possible way of recording each layout by its co-ords not sheet name, as you asked how to find sheets for a certain area, the other way may be to have a 2nd dwg with layouts as rectang blocks then xref in a shadow outline of the project then just window area and retrieve the sheet numbers. Easiest way is within layout do rectang block rescale etc to fit then CUT and paste to other dwg original co-ords. You can have multiple rectangs of different size = scale of layout.
  7. #7
    Windows 7 - 64bit
    Manufacture
    Steel Detailer
    Manufacture
    AutoCAD 2014
    May 2011
    569
    Hey guys thanks again for the input.
    ReMark - what would the process be for collecting a set of drawings (.DWGs) that do not have any keyword similarities? Is there a way you can feed a list (excel, TXT) file and get it to collect the list drawings?
    BigAl - my first explanation may have not been clear enough. I am wondering about how to find/isolated a set of .DWGs, rather than layouts. We only use the model layout in each DWG for our shop drawings. One file one drawing.
  8. #8
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Each rectang can still be a dwg name in your seperate index dwg. Just use a selection window and a list of dwg names would be created. Our GIS has all engineering plans as polygons representing the area of interest of a plan so a road intersection would be a cross shape. Depending on search area is how many polygons are retrieved.
  9. #9
    Windows 7 - 64bit
    Manufacture
    Steel Detailer
    Manufacture
    AutoCAD 2014
    May 2011
    569
    Prosteel allows my to create a list of drawings pretty easily. I'm more interest in a method to isolate the .DWGs (through windows explorer) or another way.
  10. #10
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Within lisp you can use VL to copy a dwg from one directory to another is this what you want ? If so google Bold for command example, you said you have the list just repeat as required.
  1. sorting the tree
    By andar424 in forum Autodesk Inventor
    Last Post: 16th Oct 2013, 03:51 pm
  2. Sorting a report
    By Electroman7979 in forum Electrical
    Last Post: 20th Apr 2009, 05:00 pm
  3. Sorting Linetype Scales out on other people drawings?
    By spittle in forum AutoCAD Drawing Management & Output
    Last Post: 14th Oct 2007, 04:44 pm
  4. Sorting Drawings when going to open
    By AutoCAD Slave in forum AutoCAD Drawing Management & Output
    Last Post: 8th Apr 2005, 08:41 am
