Rotate Spur Gear?
Faouweb
Add an angle constraint and then Drive Constraint
or
in Environments>Dynamic Simulation add a Rolling Cylinder on Cylinder joint and then Imposed Motion on Revolution joint.
If you can't figure it out - simply attach your assembly here.
I don't know how to do it :(
We don't have Inventor Pro :cry:
I have attached 2 Parts and 1 Assembly.
Thank you ;)
Assembly1.zip
Spur Gear test.ipt
Part8.ipt
You have attached the wrong files which will result in a delay in getting an answer.
Have you installed all Service Packs for r2013? (the correct answer is - no)
Hi Mather,
The file is a little bit big and I can not attached it, I used Pack and go but is still big.
I will put the Assembly and the Part in the attachment.
Here is what I have.
I did not installed it my self, we have a staff in the company which have access in order to install or modify applications.
---------------------------- Edit ---------------------
Is there a step by step tutorial to do it ?
Thank you :)
Part1.ipt
Design Accelerator.zip
Assembly1.zip
Edited by Faouweb
Step 1
Right click on you Design Accelerator sub-assembly and set it to Flexible as shown below.
You should now be able to drag the gear motion.
Next I will demonstrate how to Drive the motion.
(also notice in the image above your assembly references Part8, yet you attached a Part1?)
I am so happy to see the Gears rotating, but I want to add some Gears and V-Belt to make something more complicate.
How can I add Gear or V-Belt to existing one, I have tried but I am sure it's not a the good way to do it :sweat: as you can see in the picture:
http://s10.postimg.org/hk0b8baax/belt.png
Thank you :)
Notice that your gears created by the Design Accelerator are placed in a special sub-assembly in the browser and must be created in pairs.
I simply drill down and get the *.ipt files and use these like any other parts in my own assemblies and sub-assemblies.
