Results 1 to 3 of 3
    Forum Newbie
    AutoCAD 2010
    May 2014
    2
    Default Selecting Individual Layers Within XRefs
    Hello,
    I'm a fairly new AutoCAD user (AutoCAD 2012 version) so there's probably a very simple answer to this. I have a "Master" drawing with one xref inside. Im producing drawings (layouts) from this master dwg file. Im trying to freeze individual layers within the xref, I can do this by using the Layer properties manager "VP freeze" column, this is very slow. What I would like to do is select an individual layer of the xref within the viewport and freeze it using the layer dropdown list at the top, however when I click one of the layers within the xref all the layers within the xref become selected.
    How can I select individual layers within the xref?????
    Thanks
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Use the Freeze Layer button and select an object in the XREF on the layer that you want frozen.
    Drafting is a breeze.
    Forum Newbie
    AutoCAD 2010
    May 2014
    2
    Wow! thank you RobDraw, that is so simple!!! This will save many hours.....
  1. Xrefs and Layers
    By PEGAdevelopment in forum Civil 3D & LDD
    Last Post: 13th Nov 2013, 04:11 pm
  2. Replies: 3
    Last Post: 12th Jan 2012, 12:10 pm
  3. Xrefs & Layers???
    By spittle in forum AutoCAD General
    Last Post: 7th Jan 2008, 03:14 pm
  4. make layers to individual files
    By cheasie in forum AutoCAD General
    Last Post: 11th Jan 2007, 03:28 am
  5. using rtext to display filenames of individual xrefs
    By christ0j in forum AutoCAD Drawing Management & Output
    Last Post: 25th Jul 2005, 05:19 pm
Tags for this Thread
