Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 50
Thread: Simple Drawing
    Junior Member
    AutoCAD 2014
    May 2014
    19
    Default Simple Drawing
    Hello everybody
    I m new to this forum.I just want to ask what commands do I use to finish my drawing
    Im having problems wih the highlighted part.Hopefully the quality is good enough
    Thanks a lot.
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Attach your dwg file here of what you have attempted so far.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    You could try using the Circle command and the Tan-Tan-Radius option.
    Junior Member
    AutoCAD 2014
    May 2014
    19
    Thanks a lot for your replies.
    I tried the fillet command(radius 50) but it didnt work.
    Here is what I have done so far (didn't add dimensions,layers but thats not a problem)
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    The drawing is supposed to be in millimeters not in inches. Image if you will that you had a handle that was 190 inches long versus one that was 190 millimeters long. At 190mm that would be a little over 7" inches long.
    Use the acadiso.dwt template file not the acad.dwt to start your new drawing.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    A quick mockup using some temporary geometry.
  7. #7
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Your R32 arc in wrong location.
  8. #8
    Junior Member
    AutoCAD 2014
    May 2014
    19
    Quote Originally Posted by JD Mather View Post
    Attachment 48987
    Thanks .I already fixed that but unfortunately I uploaded the wrong file.
    @Remark the drawing its in mm not in inches.
    Thanks a lot for the help.I think im able to do it.I will try tomorrow and get back to you.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    "@Remark the drawing its in mm not in inches."
    If that is true why when I run the -dwgunits command it reports back the following?
    If you are happy working the way you are then by all means keep at it. Good luck.
  10. #10
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Professional 64 bit
    HP EliteBook 8570w
    Intel Core i7-3720QM 2.60GHz
    16GB
    NVIDIA Quadro K2000M
    HP
    Civil
    Tiger's Discipline Details
    Education /support
    Civil
    Support/Education/Retail
    Civil 3D 2016
    Nov 2006
    FjÀrdhundra, Sweden
    5,148
    reMark, How do you know where the 42-dimension is? That is, where the radius 52 is suppose to end?
    MTJIGSTRING = BAZINGA
  1. Help drawing this simple thing?
    By kad_911 in forum AutoCAD Beginners' Area
    Last Post: 14th Jun 2013, 09:13 pm
  2. need a simple 3d autocad drawing
    By rossboy in forum AutoCAD 3D Modelling & Rendering
    Last Post: 18th Mar 2011, 04:54 pm
  3. Need help drawing... Simple
    By jmaurerhrtlndstl in forum AutoCAD Drawing Management & Output
    Last Post: 18th Sep 2010, 12:34 pm
  4. simple wheel drawing
    By endlasuresh in forum AutoCAD Beginners' Area
    Last Post: 18th May 2010, 03:50 pm
  5. Can I import a simple line drawing....
    By RSWORDS in forum AutoCAD General
    Last Post: 13th May 2005, 07:30 pm
