Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 50
Thread: Simple Drawing
  1. #11
    Junior Member
    AutoCAD 2014
    May 2014
    19
    "@Remark the drawing its in mm not in inches."
    If that is true why when I run the -dwgunits command it reports back the following?
    Attachment 48995
    If you are happy working the way you are then by all means keep at it. Good luck.
    Im pretty sure I set the units to mm.(used _units command)
    Is there another way how to do it?Am I doing something wrong?
    Thanks for your help.
  2. #12
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,728
    Line tangent to arc.
    Dimension at min distance. (71mm from centerline of part)
  3. #13
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,728
    Quote Originally Posted by ducky29 View Post
    Im pretty sure I set the units to mm.(used _units command)....
    Are you using AutoCAD 2005 as indicated in your profile? Does r2005 support the -dwgunits command?
  4. #14
    Junior Member
    AutoCAD 2014
    May 2014
    19
    Quote Originally Posted by JD Mather View Post
    Yes im using 2005 version. When I type _dwgunits it pops us the same window as in Remark's post.
  5. #15
    Junior Member
    AutoCAD 2014
    May 2014
    19
    Here is what I have done so far.
    What command do I have to use to make the corner "smoother" (R 1,5)?
    I cant get it done by using chamfer.
    d1.dwg
  6. #16
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    When working in metric units I suggest you use a metric template file such as acadiso.dwt rather than the default acad.dwt.
  7. #17
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    You can round off a square corner using the FILLET command and indicating the radius you would like AutoCAD to use.
  8. #18
    Junior Member
    AutoCAD 2014
    May 2014
    19
    Thanks. Ill use acadiso.dwt starting from now.(Just need to change the drawing limits since I print my drawings in A4.)
  9. #19
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    Most CAD users pay no mind to LIMITS.
  10. #20
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,728
    .... When I type _dwgunits ....
    That is not the same as what I wrote. I wrote -dwgunits, not _dwgunits.
  1. Help drawing this simple thing?
    By kad_911 in forum AutoCAD Beginners' Area
    Last Post: 14th Jun 2013, 09:13 pm
  2. need a simple 3d autocad drawing
    By rossboy in forum AutoCAD 3D Modelling & Rendering
    Last Post: 18th Mar 2011, 04:54 pm
  3. Need help drawing... Simple
    By jmaurerhrtlndstl in forum AutoCAD Drawing Management & Output
    Last Post: 18th Sep 2010, 12:34 pm
  4. simple wheel drawing
    By endlasuresh in forum AutoCAD Beginners' Area
    Last Post: 18th May 2010, 03:50 pm
  5. Can I import a simple line drawing....
    By RSWORDS in forum AutoCAD General
    Last Post: 13th May 2005, 07:30 pm
