Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 50
Thread: Simple Drawing
  1. #21
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,728
    Lines should be tangent to arc at left.
    Dimensions don't match the original drawing.
  2. #22
    Super Member
    AutoCAD 2012
    Jun 2012
    902
    Default Dimensional discrepancy?
    Yeah, there seems to be some discrepancy in the original dimensions, as though it was first done in inches, then converted to metric, so that you cannot perfectly hold all of the dimensions, e.g.,
    When all you have is a hammer, everything looks like a nail.--
    “Doc, it hurts when I do this.” “Well, don’t do that!”
    “Well, if you don’t know, I’m certainly not going to tell you!”
  3. #23
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,728
    All of the dimensions from the original drawing can be honored out to as many decimal places as desired.
  4. #24
    Super Member
    AutoCAD 2012
    Jun 2012
    902
    Quote Originally Posted by JD Mather View Post
    May be, as the original is quite blurry and a dimension has even been written in by hand for whatever reason.
  5. #25
    Super Member
    AutoCAD 2012
    Jun 2012
    902
    It seems to me this is another "one of those". The 64mm dim could be very misleading unless the center point is very clearly shown offset. But even then, the 64 is not a necessary dimension. Better to just leave it off.
  6. #26
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    The instructor would have been better off selecting pertinent drafting assignments had he/she used French's book "Engineering Drawing" copyright 1947!
    It's pretty amazing the number of these types of assignments that come through with errors and/or omissions in them. Apparently no one checks the diagrams for accuracy, prior to publishing; everyone is keyed in on the text.
  7. #27
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,728
    Quote Originally Posted by neophoible View Post
    You are assuming that the center of the arc is coincident.
    Dimensions on a drawing (unless shown as reference) take precedence over all else.
    In typical classroom type problems these are the tricks that separate the "A" students from the "B" students.
    Instructors look for this attention to detail and throw in tricky stuff like this.
    There is nothing wrong in this part/assignment.
    See Post #7 where I clearly show the dimensions as given in the original drawing.
  8. #28
    Super Member
    AutoCAD 2012
    Jun 2012
    902
    Or maybe you are assuming I'm assuming? The 64mm is a dimension, but to what? Maybe I know, if I'm the one originating it. Experience tells me that such a drawing is too easily misinterpreted. The student should be taught to make it clear. It seems to me, this is a case where that is not the case. However, it is a good problem for demonstrating what happens when you don't make it clear. (Hmm. I wonder if anyone can understand that?)
  9. #29
    Super Member
    AutoCAD 2012
    Jun 2012
    902
    I think the drawing in post #2 is more appropos to the discussion, and it isn't tricky, it's misleading or incorrect. The 64mm is not an exact dimension when holding all the others exact. Post #7 is where the solution comes in. If the student is told that the center is not along the line, that the 64mm is not exact, then you have a more bona fide problem. Or you could just drop the 64mm dimension altogether.
  10. #30
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,728
    I think the drawing in post #2 is more apropos to the discussion, and it isn't tricky,[I][I] it's misleading or incorrect. The 64mm is not an exact dimension when holding all the others exact. Post #7 is where the solution comes in.
    Post 2 and 7 are the exact same file.
    You are wrong, the drawing is correct. It is an exact dimension holding all others dimensions exactly as given. I am done with this one.
    BTW, it isn't tricky or misleading for the "A" students.
  1. Help drawing this simple thing?
    By kad_911 in forum AutoCAD Beginners' Area
    Last Post: 14th Jun 2013, 09:13 pm
  2. need a simple 3d autocad drawing
    By rossboy in forum AutoCAD 3D Modelling & Rendering
    Last Post: 18th Mar 2011, 04:54 pm
  3. Need help drawing... Simple
    By jmaurerhrtlndstl in forum AutoCAD Drawing Management & Output
    Last Post: 18th Sep 2010, 12:34 pm
  4. simple wheel drawing
    By endlasuresh in forum AutoCAD Beginners' Area
    Last Post: 18th May 2010, 03:50 pm
  5. Can I import a simple line drawing....
    By RSWORDS in forum AutoCAD General
    Last Post: 13th May 2005, 07:30 pm
