tormax Posted May 18, 2014 Share Posted May 18, 2014 I have tried a various tricks and several programs such as Inventor,Solidworks and 3ds max plus lot of help from Google,but at the end I can not find proper way to import somehow stl files as soldis in Autocad. Does someone had luck with that? There are only 2-3 paid apps which unfortunately I can not buy right now... Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 18, 2014 Share Posted May 18, 2014 Works fine for me using Inventor or SolidWorks. Pretty sure luck wasn't involved - only logic. You have not provided ANY useful information to help solve your problem. Quote Link to comment Share on other sites More sharing options...
tormax Posted May 20, 2014 Author Share Posted May 20, 2014 With Solid works I receive error message about the number of the faces,with Inventor the situation is again without result. This STl is generated with Alphacam if does matter at all... any suggestions? I can not upload the sample here so You can look at it in Dropbox: https://www.dropbox.com/s/hdal3v3zcwzckhn/stl.rar Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 20, 2014 Share Posted May 20, 2014 Sorry, I don't go to third party sites to download files (unless it is Autodesk 360) and I don't have an rar extractor. How familiar are you with stl files? They are coarsely faceted planar surfaces - generally of little use other than for reference in an engineering software. In SolidWorks you have to use the Scanto3D add-in once the number of faces exceeds a certain number. Quote Link to comment Share on other sites More sharing options...
tormax Posted May 20, 2014 Author Share Posted May 20, 2014 Thanks JD,unfortunately I`m completely new with stl files,but I`ll have to get familiar with them. Anyway using scanto3d now i can open stl,but seems now will be not possible to convert this type of files to solids and to edit them in Autocad. Can you please look at the attached sample?stl sample1.zip Quote Link to comment Share on other sites More sharing options...
