Results 1 to 7 of 7
    Full Member
    Civil 3D 2014
    Dec 2013
    Dallas, TX
    79
    Default On error checking...
    Is it necessary to put error checking in a program that doesn't change any variables? In other words, does it do more than just the resetting of user settings if a cancel/escape occurs? Thanks
    Full Member
    Civil 3D 2014
    Dec 2013
    Dallas, TX
    79
    Is there anybody out there?
    Super Member
    AutoCAD 2012
    Jun 2012
    902
    You don't have to do error checking. It is up to you. However, if the program can go wrong, it helps to have the error checking instead of just crashing or returning nothing, leaving the user confused and frustrated.
    When all you have is a hammer, everything looks like a nail.--
    “Doc, it hurts when I do this.” “Well, don’t do that!”
    “Well, if you don’t know, I’m certainly not going to tell you!”
    Full Member
    Civil 3D 2014
    Dec 2013
    Dallas, TX
    79
    Alright thanks neophoible,
    So if I'm hearing you right, it's good practice to at least have the "An error occurred, user settings reset" line so as to not leave someone hanging and just good cleanly courteousness. Thanks for stepping up.
    Code:
     (princ  "\nAttention! An error has occurred!")
        (princ  "\nFWTCAD  RCALC now restoring the user enviroment.")
  5. #5
    Super Member hmsilva's Avatar
    Multi-disciplinary
    AutoCAD 2016
    Dec 2012
    Cascais, Portugal
    531
    Error handling,
    is not only to reset system variables, is advisable to use an error handling function whenever we access an external file (txt, xls, ...) to open, to read or to write, to ensure that the file is properly closed on failure, if not, the external file will remain marked as "opened" and to access that file again, you will have to close the AutoCAD session and start a new one...
    The same is applicable in ObjectDBX and other objects created, to release objects on error...
    HTH
    Henrique
  6. #6
    Full Member
    Civil 3D 2014
    Dec 2013
    Dallas, TX
    79
    Thank you hmsilva
  7. #7
    Multi-disciplinary
    AutoCAD 2016
    Dec 2012
    Cascais, Portugal
    531
    You're welcome, LosGirk
    Henrique
  1. Adding Error Checking or Conditionals (and combining functions)?
    By ILoveMadoka in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Dec 2011, 12:00 am
  2. Need help on Checking a selection set
    By pryzmm in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Nov 2011, 02:50 pm
  3. Clearance checking?
    By Sophisto in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Jun 2010, 08:14 pm
  4. checking the polylines
    By vivekgrs in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Sep 2006, 05:12 am
