Results 1 to 7 of 7
Thread: Hatch Creation
    Senior Member
    nicolas's Computer Details
    Windows 7
    Intel Dual Core 64 Bits
    2 GB
    AutoCAD 2015
    Jan 2008
    Rose Hill, Republic of Mauritius
    420
    Default Hatch Creation
    Hi,
    I need to create a rectangular tile hatch that is 200 (w) x 300 (h). So far using USER, I have been able to do square tiles (100x100 and 300x300). Is there any simple way to create a hatch pattern file for such rectangular tiles?
    Thanks.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,148
    Try something like this:-
    *TILERECT,
    0, 0, 0, 0, 300
    90, 0, 0, 0, 200
    Senior Member
    Windows 7
    2 GB
    AutoCAD 2015
    Jan 2008
    420
    Hi Eldon,
    Thanks for the info. I have created a text PAT file with the content you specified. However I am having an error in pattern file dialogue box when applying it to a closed polyline. Would you please help me on this? Thanks.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,148
    The problem may be that the pattern file name HAS to be exactly the same as the name after the * in the first line of the definition file.
    So the first line should be (for you) *Tiles200x300 instead of *TILERECT. I don't think that upper and lower case matter.
    Also there should be a blank line at the end of the file.
  5. #5
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Rather than 200x300 why not 100x150, plus 100x200, plus 100x300 if you make your hatch scale = 2 for 100x150 then it will be 200x300 a 400x600 is a scale of 4 and so on, less patterns but with correct scaling ratio achieve correct result sq tile 100x100. Even make the pattern 1x1.5 then its scale is size required =200
  6. #6
    Senior Member
    Windows 7
    2 GB
    AutoCAD 2015
    Jan 2008
    420
    Hi,
    Still problem with the PAT file. Now it is:
    Bad pattern definition file:
    Missing parameter on line 3.
    Here is the content of the file:
    *Tiles200x300,
    0, 0, 0, 0, 300
    90, 0, 0, 0, 200
    BIGAL is right concerning the 100x150 tiles. It is more logic and productive that way.
    Thanks for your help.
  7. #7
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,148
    It does not look as if you have a blank line at the end of the file
    I can't attach the actual file that works for me, because CadTutor does not allow uploading .pat files
    So please edit the file extension to .pat from .txt
  1. 3D net creation
    By heartache in forum AutoCAD 3D Modelling & Rendering
    Last Post: 27th Apr 2012, 01:12 pm
  2. 3D net creation
    Last Post: 27th Apr 2012, 11:38 am
  3. 3d pdf creation
    By DJMDesign in forum AutoCAD General
    Last Post: 23rd Jul 2009, 02:20 pm
  4. Rib Creation
    By graann in forum Autodesk Inventor
    Last Post: 2nd Sep 2008, 07:06 pm
Tags for this Thread
