Vagulus Posted May 19, 2014 Share Posted May 19, 2014 Try it and Inventor starts, sends a dialog "There was a problem sending the command to the program" Does anyone know what the problem is (it's new to me and it started today), and how to fix it? Thanks Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 19, 2014 Share Posted May 19, 2014 What happens if you open files from within the program? Quote Link to comment Share on other sites More sharing options...
Vagulus Posted May 19, 2014 Author Share Posted May 19, 2014 What happens if you open files from within the program? That worked fine. However, the problem is currently solved. Something came up to the surface of my memory from the time I spent working with AutoCAD. I had been doing some maintenance on my machine which included a registry check and repair. This appears to have some strange effect on Autodesk products, and they do funny things after that. Solving the problem involves going to Control Panel -> Uninstall -> Repair. Autodesk fixes itself. Sorry to take up your time. Quote Link to comment Share on other sites More sharing options...
