[INV2014] Add tabs to revolved part and make correct flatten
Guest kruuger
Guest kruuger
hello
is there any way to create part like in attached file and add tabs on each side so part can be correctly unfolded ? need dxf shape.
there are two thickness 2, 3 which are very important. i think they are complicate a little since we can build sketch on sides.
thanks
kruuger
123.ipt
Guest kruuger
Sketch1 is not fully defined.
What is the angle?
there will be a lot of parts one above another. it is just an example
attached is surface work. now work on solids. hundreds of parts.
kruuger
You do not need to draw a rectangle to get a Contour Roll (conic sheet metal) all you need is a single line.
Guest kruuger
ah yes, that's good. easier and faster. thanks
