How to draw a 2degree curve
If I am plotting a property description, and the next call is a 2degree curve to the left, at a distance of 600'. How do I go about plotting that?
I suspect you have more information than you have provided here.
Can you delete most of the file and then attach the area of concern here?
this might help,
draw a line straight with Ortho on 600'
rotate it 2 degrees,
use the polyline (PL) command, after you pick the start point (end point of the rotated line),
select Arc (A), then pick the other end point.
their are other possible ways but this was the first I could think of.
