Bill Tillman Posted May 20, 2014 Share Posted May 20, 2014 I'm using this neat little function that Lee-Mac posted in the AutoDesk forum a few weeks ago: (defun numpos ( str ) (if (wcmatch str "*#*") (- (strlen str) (length (vl-member-if '(lambda ( x ) (< 47 x 58)) (vl-string->list str)))) ) ) It works great but I'm having some other troubles with another part of my code so I toggled a break point and started stepping through the code to debug it. The trouble now is when it hits this code it all comes to a screeching halt and brings up a new window in the LISP IDE called "Source #4" with this in it: ;;; Copied to window at 9:40 AM 5/20/14 (LAMBDA (X) (< 47 X 58)) ;;; End of text LAMBDA is still something I'm very weak with so I don't fully understand what's happening. Any further attempts to use the F8 key to continue causes a new "Source #5....#6....etc) window to open up with the same text in it and the code just halts. If I click on the green arrow to continue it will go on, but I no longer get to step through the code to see what's happening. Run the code without the breakpoint allows it to run without this Window #4... etc. I found a post from almost a year ago where this was addressed but I don't think it was ever resolved. Quote Link to comment Share on other sites More sharing options...
Bill Tillman Posted May 20, 2014 Author Share Posted May 20, 2014 It does appear that LAMBDA is the culprit in this. Can anyone recommend a substitute for Lee-Mac's code....I will be very glad to use LAMBDA but not until I can get the code debugged and with LAMBDA all attempts to step through it are failing. I did at least have one of the modules write some of the variables to a text file before the LAMBDA code runs and I can now at least confirm that the variables I'm having trouble with are correct. It's just the other section of the code is not behaving as anticipated and unless I can step through it, I really can't find out what's going wrong. UPDATE: The text file process helped me find out what was going wrong. So my debug mission is accomplished. Now if anyone can shed some light on LAMBDA and debugging I'd be very glad to hear about it. Quote Link to comment Share on other sites More sharing options...
neophoible Posted May 20, 2014 Share Posted May 20, 2014 I don't know what causes the problem, but lambda is just a way to create a function without defining one. Perhaps the problem has to to with the way it interacts with the vl... extended functions? If you need to get around it, perhaps you can just define a named function. Quote Link to comment Share on other sites More sharing options...
