Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
  1. #11
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,588
    Copy and paste the code into notepad save as say Lothatch.lsp the data file is just as per example below, then Appload choose Lothatch.lsp
    lotnum,layername
    lotnum,layername
    lotnum,layername
    106,10% built
    It works on your dwg do you know how to create this simple file from excel ?
    I could have done more re finding file but thats what learning is about search for FINDFILE examples
  2. #12
    Forum Newbie
    AutoCAD 2014
    May 2014
    7
    Hello CAD wizards. Thank you all for you insight and help. I am presently researching and slowly teaching myself LISP. As for the code kindly submitted above by "BIGAL" with help from "lee-mac", im not sure how to implement this. Would this code be for cad itself or for excel, or perhaps both. Perhaps in time I will understand this further, but with time constraints I'm hoping someone may have the time to review what has been suggested and give me some direction as to implementing such a code.
    Look forward to your imput
  3. #13
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,588
    Ok save code to notepad change the 1 line to this (setq fopen (open "c:/users/test.csv" "R")) and save as a lisp file hatchlots.lsp
    Copy this to notepad and save as c:\users\test.csv
    Code:
    106,10% complete
    107,20% complete
    108,30% complete
    109,40% complete
    Then
    appload hatchlots.lsp
    dwg should be different now
  4. #14
    Forum Newbie
    AutoCAD 2014
    May 2014
    7
    Hello bigal, I created a csv file as instructed with one column lotnum and one column as layer name. I then created a mm.lsp using the code you provided but have been unable to get this to work. after appload I chose the lisp file, then cad ask for file name Am I missing a step or perhaps misunderstand some of your direction?
    I have attached the csv file (created in excel) and the lisp file for your review.
    thanks
  5. #15
    Forum Newbie
    AutoCAD 2014
    Sep 2014
    3
    Has anyone figured this out if it actually works? This is exactly what I am looking for.
  6. #16
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,588
    I wrote it and it works did you try it ?
  7. #17
    Forum Newbie
    AutoCAD 2014
    Sep 2014
    3
    I followed the steps from your posts above, however I'm having the same issues as mjm. I appload the lisp file, then it says "Unable to recognize command "hatchlots.lsp" Please Try again" It Then asks for a file name, and when i click on that it says bad argument type. Not sure whether I'm missing a step or something? should the tagged lots in the drawing change colors for the specific ones used in the test csv file?
  1. Data Extraction to Excel turns data into dates.
    By arkitectin in forum AutoCAD Drawing Management & Output
    Last Post: 8th May 2014, 05:31 pm
  2. Extracting Data from Excel to CAD or CAD to Excel
    By shivakumar in forum AutoCAD LT
    Last Post: 3rd Sep 2013, 07:40 pm
  3. Can't edit attribute when inserting excel data that has 3 lines of data
    By Findermb in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 12th Jun 2013, 02:34 pm
  4. Replies: 2
    Last Post: 5th Jan 2011, 09:40 pm
  5. Data Link Auto Update
    By guitarguy1685 in forum AutoCAD Drawing Management & Output
    Last Post: 17th Aug 2010, 07:57 pm
Tags for this Thread
