something that doesn't have a style thing in Style Manager?
I've made a 2d block and I want to be able to schedule it after applying a property set definition. So I can fill out each bit of info individually for each block. But later, I have to go into each block of the same type to change a common setting, like cost.
What I think I want to do is get these blocks into a "style", so I can make some global changes. Like lets say I've a block of a 24" table, and a block of a 48" table. And then I scatter them throughout the drawing. Then I schedule them, including cost. Then the cost changes on the 24" table. I don't want to edit each block, I want to go into the style manager and change the style property set settings.
Furniture styles, equipment styles, etc?
If anyone cares, you use multi view blocks. So you can make a multi view block, and attach a property set to its style. Then attach another one to the block itself iffin you want.
So with blocks, you can schedule any damn thing you want.
This is a hoot
