WindowsIHateYou Posted May 22, 2014 Share Posted May 22, 2014 Is there a way to generate a "midpoint" line between two other lines? Acad 2008, drawing has no vertical. Lines are irregular, not perfectly straight. Essentially, I am trying to generate a Centerline between two irregular edges of pavement. I don't mind solutions that require fine-tuning, or jagged lines that need to be smoothed/curved out. I'm just looking for the solution that saves me the most time. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted May 22, 2014 Share Posted May 22, 2014 Have you looked into the m2p option? Read here: http://docs.autodesk.com/ACD/2014/ENU/index.html?url=files/GUID-04C9F013-46A3-430E-A085-BF254EA6B1D6.htm,topicNumber=d30e404851 This may be exactly what you're looking for, but if not there may be a LISP routine floating around the web somewhere. Quote Link to comment Share on other sites More sharing options...
rkent Posted May 22, 2014 Share Posted May 22, 2014 This lisp routine will work. http://www.cadalyst.com/general-software/autolisp-solutions-create-long-intermediate-terrain-contours-3103 Quote Link to comment Share on other sites More sharing options...
eldon Posted May 22, 2014 Share Posted May 22, 2014 You could go to Jeffrey P Sanders web site, and try the Rolling Ball lisp. It would seem to do what you want. Rolling_ball Thanks to Guenther Bittner, the program is complete. Find the mid-boundary between two polylines. Version 4+ now available. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted May 22, 2014 Share Posted May 22, 2014 Have you looked into the m2p option? I couldn't remember when M2P was introduced, but it looks like it was there for 2008, and even earlier. http://thecadgeek.com/blog/2008/12/mid-between-2-points-osnap/ Quote Link to comment Share on other sites More sharing options...
SYahoo Posted May 22, 2014 Share Posted May 22, 2014 1. Draw a line connecting the ends of each line together. 2. Draw a line from the mid point of each of these connecting lines Quote Link to comment Share on other sites More sharing options...
WindowsIHateYou Posted May 22, 2014 Author Share Posted May 22, 2014 Have you looked into the m2p option? That one is new to me. Not what I am looking for on this specific task, but will be very helpful for other things. Thanks This lisp routine will work.http://www.cadalyst.com/general-software/autolisp-solutions-create-long-intermediate-terrain-contours-3103 I couldn't find the download anywhere, or even the "get the code" section where they said the download would be. ;/ Odd... You could go to Jeffrey P Sanders web site, and try the Rolling Ball lisp. Wow. Who cares about work? I could just stare at that command be performed for hours on end. It looks like this fits my needs. Thanks P.S., for anybody else who tries it, the command to start the lisp is "rollin". It wasn't obvious for non-coders, and my fingers kept typing rollinG for half an hour until I figured it out. 1. Draw a line connecting the ends of each line together.2. Draw a line from the mid point of each of these connecting lines To clarify, the lines have multiple segments. If they were single segment lines, this would work though. Quote Link to comment Share on other sites More sharing options...
neophoible Posted May 22, 2014 Share Posted May 22, 2014 I couldn't find the download anywhere, or even the "get the code" section where they said the download would be. ;/ Odd...Try the following steps, noting that I am zoomed in on the pages a bit and that I'm actually showing portions of 2 pages here: Quote Link to comment Share on other sites More sharing options...
WindowsIHateYou Posted May 23, 2014 Author Share Posted May 23, 2014 LOL, thanks. Mouseover did nothing on that button so I thought it wasn't a button, and was just a poor label for the "Print" icon next to it. Quote Link to comment Share on other sites More sharing options...
WindowsIHateYou Posted May 29, 2014 Author Share Posted May 29, 2014 Well I couldn't figure out the variables on "rollin" to get it smooth through a curve. I did manage to figure out the "contours" variables. blue= orig red= contours yellow= rollin Quote Link to comment Share on other sites More sharing options...
austinr01 Posted May 29, 2014 Share Posted May 29, 2014 I frequently want to move an item or draw a line halfway between two points and formerly would draw a construction line, pick the midpoint, and then erase the line afterwards. There is an object snap that is not on the selection list called m2p that directly selects a point midway between two other points. I created my own icon that works as an object snap and use it many times throughout the day.This is the easiest way to find a midpoint between two points. Or You can simply choose it from snap tools. You can hold [shift] then press right button mouse then choose it from the list . I always refer video-tutorials.net , Because it is best institution for Cad Software Design and Solution, If you have any problem in autocad Design , then you can contact with this company : info@video-tutorials.net. Hope this information help for you Thanks dear. Quote Link to comment Share on other sites More sharing options...
WindowsIHateYou Posted August 28, 2014 Author Share Posted August 28, 2014 (edited) This lisp routine will work.http://www.cadalyst.com/general-software/autolisp-solutions-create-long-intermediate-terrain-contours-3103 I'm on a new computer, so I went to download the lisp again, and the Cadalyst site hates me and gives me a "403 Forbidden" when I try to download the tip. I found it elsewhere, but I'm wondering if anybody else is getting the 403. Edited August 28, 2014 by WindowsIHateYou Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 29, 2014 Share Posted August 29, 2014 Works fine for me today. Quote Link to comment Share on other sites More sharing options...
WindowsIHateYou Posted August 29, 2014 Author Share Posted August 29, 2014 still doesn't work for me. the "download tip" link on this page: http://cadtips.cadalyst.com/surfaces/intermediate-terrain-contours Quote Link to comment Share on other sites More sharing options...
Dana W Posted August 29, 2014 Share Posted August 29, 2014 still doesn't work for me. the "download tip" link on this page: http://cadtips.cadalyst.com/surfaces/intermediate-terrain-contours Do you have to be a "member" to download? I didn't sign up, and it doesn't work for me either. Quote Link to comment Share on other sites More sharing options...
WindowsIHateYou Posted August 30, 2014 Author Share Posted August 30, 2014 Do you have to be a "member" to download? I didn't sign up, and it doesn't work for me either. I wasn't before, but I became a member to try. It still didn't work. so I've tried 2 desktops and a mobile, and I still get the same error. Quote Link to comment Share on other sites More sharing options...
Dana W Posted August 30, 2014 Share Posted August 30, 2014 I wasn't before, but I became a member to try. It still didn't work. so I've tried 2 desktops and a mobile, and I still get the same error.OK, here's another wild guess. Try a different browser. I'm using Chrome. Quote Link to comment Share on other sites More sharing options...
Patrick Hughes Posted August 30, 2014 Share Posted August 30, 2014 I know Cadalyst has had some website problems recently. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 2, 2014 Share Posted September 2, 2014 Works fine for me this morning as well. No sign in needed. I'll just post them here since they are free to distribute. contours LSP-RPL lsp.zip Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted September 2, 2014 Share Posted September 2, 2014 Nancy Johnson, Content Editor at Cadalyst posted details on the recent Cadalyst.com outage over on LinkedIn (in the Cadalyst group) if anyone is interested. Quote Link to comment Share on other sites More sharing options...
