Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Senior Member teknomatika's Avatar
    AutoCAD 2009
    Sep 2010
    Portugal
    247
    Default Draw near points of text entities
    I look for a routine that will resolve the following task:
    1 - I select a group of text entities (in this case numbers)
    2 - Then I draw a point near the position of one
    3 - Finally, the routine must be able to replicate the point in the other text strings, maintaining the same close relationship defined in step 2
    Attached a drawing to better understand
    Tanks for help!
    Full Member JamCAD's Avatar
    Civil
    JamCAD's Discipline Details
    Civil Design and Drafting
    Civil
    AutoCAD 2014
    Aug 2012
    Brisbane, Australia
    75
    Default Try this
    Try this
    Code:
    (defun c:txtpt (/ txt1 txtpt pt ss i ptsz ang dist ip pt1 pt2 pt3 pt4)
      (setq    txt1  (progn (princ "Pick First M/Text Object")
                 (ssget "_+.:E:S" '((0 . "*TEXT")))
        txtpt (cdr (assoc 10 (entget (ssname txt1 0))))
        pt    (getpoint txtpt "\nSelect loction of point")
        ss    (progn (princ "Select All M/Text Objects")
                 (ssget '((0 . "*TEXT")))
        i     0
        ptsz  (getreal "\nHow large should the point be?")
        ang
              (angle txtpt pt)
        dist
              (distance txtpt pt)
      (while (< i (sslength ss))
        (setq ip  (polar
            (cdr (assoc 10 (entget (ssname ss i))))
            ang
            dist
          pt1 (polar ip (/ pi 2) (/ ptsz 2))
          pt2 (polar ip (* pi 1.5) (/ ptsz 2))
          pt3 (polar ip 0 (/ ptsz 2))
          pt4 (polar ip pi (/ ptsz 2))
        (command "line" pt1 pt2 "")
        (command "line" pt3 pt4 "")
        (command "circle" ip (/ ptsz 4))
        (setq i (1+ i))
    AutoCAD 2009
    Sep 2010
    Portugal
    247
    That's it. However, it is not necessary to draw the symbol as in my example. My intention was that it be interpreted as a point. I just want to be drawn to simple point entity.
    I appreciate the update.
    AutoCAD 2009
    Sep 2010
    Portugal
    247
    I think this way solves what I want.
    Code:
    (defun c:txtpt (/ txt1 txtpt pt ss i ptsz ang dist ip)
        i     0
        ang
              (angle txtpt pt)
        dist
              (distance txtpt pt)
        (setq ip  (polar
            ang
            dist
        (command "point" ip)
        (setq i (1+ i))
  5. #5
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    3,005
    Code:
    (command "point" "_non" ip)
  6. #6
    AutoCAD 2009
    Sep 2010
    Portugal
    247
    pBe,
    tanks!
  7. #7
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,246
    Try ..
    Code:
    (defun c:Test (/ *error* c s n sn e aa ab ac)
      ;;    Tharwat 23.05.2014        ;;
      (defun *error* (msg)
        (command "_.ucs" "_w")
        (if c (setvar 'cmdecho c))
        (if (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")
          (princ msg)
          (princ (strcat "Error : < ** " msg " ** >"))
      (if (zerop (getvar 'PDMODE))
        (setvar 'PDMODE 34)
      (setq c (getvar 'cmdecho))
      (setvar 'cmdecho 0)
      (if (setq s (ssget '((0 . "TEXT"))))
        (repeat (setq n (sslength s))
          (setq sn (ssname s (setq n (1- n))))
          (setq e (textbox (list
                             (cons -1 sn)
          (command "_.ucs" "Object" sn)
          (setq aa (car e)
                ab (cadr e)
                ac (list (car ab) (cadr aa))
          (command "_.point"
                   "_non"
                   (list (car ac)
                         (- (cadr ac) (/ (cdr (assoc 40 (entget sn))) 2.))
      (setvar 'cmdecho c)
    AutoCAD 2009
    Sep 2010
    Portugal
    247
    Tharwat,
    tanks!
    I appreciate the work. As always, perfect.
    It is an interesting option and that also solves my need.
    However, I prefer the solution already presented in this thread, because it allows the set point position for each text string.
    The location of the point shown in the drawing that I have attached, is just one example.
    The main idea is that the position of the point relative to the text string can be pre-defined.
  9. #9
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,246
    Quote Originally Posted by teknomatika View Post
    Tharwat,
    tanks!
    Happy to hear that .
    Not a problem , I just wanted to make life easier as best as I can .
    Good luck .
  10. #10
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,590
    Here is another way to approach the task:
    Code:
    ;; Text Point  -  Lee Mac
    ;; Prompts the user to specify the location of a point relative to a single text object
    ;; and generates a point in the same location relative to every text object in a selection.
    (defun c:txp ( / ang ent enx idx ocs sel vec )
        (while
            (progn (setvar 'errno 0)
                (setq ent (car (entsel "\nSelect source text object: ")))
                (cond
                    (   (= 7 (getvar 'errno))
                        (princ "\nMissed, try again.")
                    (   (null ent) nil)
                    (   (/= "TEXT" (cdr (assoc 0 (entget ent))))
                        (princ "\nSelected object is not a text object.")
        (if (and (= 'ename (type ent))
                 (setq vec (getpoint "\nSpecify point: "))
                 (setq sel (ssget '((0 . "TEXT"))))
                (setq
                    enx (entget ent)
                    ang (cdr (assoc 050 enx))
                    ocs (cdr (assoc 210 enx))
                    vec
                    (mxv
                        (mxm
                            (list
                                (list (/ 1.0 ((lambda ( box ) (- (caadr box) (caar box))) (textbox enx))) 0.0 0.0)
                                (list 0.0 (/ 1.0 (cdr (assoc 040 enx))) 0.0)
                               '(0.0 0.0 1.0)
                            (mxm
                                (list
                                    (list (cos ang)     (sin ang) 0.0)
                                    (list (- (sin ang)) (cos ang) 0.0)
                                   '(0.0 0.0 1.0)
                                (mapcar '(lambda ( v ) (trans v ocs 0 t))
                                        (1.0 0.0 0.0)
                                        (0.0 1.0 0.0)
                                        (0.0 0.0 1.0)
                        (mapcar '- (trans vec 1 0) (trans (cdr (assoc 10 enx)) ent 0))
                (repeat (setq idx (sslength sel))
                    (setq enx (entget (ssname sel (setq idx (1- idx))))
                    (entmake
                        (list
                           '(0 . "POINT")
                            (cons 10
                                (mapcar '+ (trans (cdr (assoc 10 enx)) ocs 0)
                                    (mxv
                                        (mxm
                                            (mapcar '(lambda ( v ) (trans v 0 ocs t))
                                                    (1.0 0.0 0.0)
                                                    (0.0 1.0 0.0)
                                                    (0.0 0.0 1.0)
                                            (mxm
                                                (list
                                                    (list (cos ang) (- (sin ang)) 0.0)
                                                    (list (sin ang)    (cos ang)  0.0)
                                                   '(0.0 0.0 1.0)
                                                (list
                                                    (list ((lambda ( box ) (- (caadr box) (caar box))) (textbox enx)) 0.0 0.0)
                                                    (list 0.0 (cdr (assoc 040 enx)) 0.0)
                                                   '(0.0 0.0 1.0)
                                        vec
    ;; Matrix Transpose  -  Doug Wilson
    ;; Args: m - nxn matrix
    (defun trp ( m )
        (apply 'mapcar (cons 'list m))
    ;; Matrix x Matrix  -  Vladimir Nesterovsky
    ;; Args: m,n - nxn matrices
    (defun mxm ( m n )
        ((lambda ( a ) (mapcar '(lambda ( r ) (mxv a r)) m)) (trp n))
    ;; Matrix x Vector  -  Vladimir Nesterovsky
    ;; Args: m - nxn matrix, v - vector in R^n
    (defun mxv ( m v )
        (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
    The above will account for the varying position, rotation, width, height & orientation of every text object in the selection, and will also perform correctly under all UCS & View settings.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  1. adding text entities
    By Jessica28 in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Mar 2014, 11:21 am
  2. Place points on all Autocad entities
    By 4DCES in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Feb 2012, 02:22 pm
  3. Selecting entities using the draw order
    By teknomatika in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Apr 2011, 08:48 pm
  4. autolisp routine to read coordinates and insert entities points
    Last Post: 22nd Sep 2010, 06:51 pm
  5. [Civil 3d 2009] arrange cogo points entities
    By coeziv in forum Civil 3D & LDD
    Last Post: 25th Mar 2009, 03:30 am
Tags for this Thread
