madriver Posted May 27, 2014 Share Posted May 27, 2014 I am getting a fatal error (Internal Error: !scandr.cpp@1117:@eLockViolation). I have run an audit, full purge and re-saved several times. An odd thing occurs. I will do a “saveas” and then close the file and it will ask me again if I want to “save changes” the file again. Any thoughts?... Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 27, 2014 Share Posted May 27, 2014 What program are you actually using? Are you working over a network? Is your program up-to-date with all service packs? Quote Link to comment Share on other sites More sharing options...
madriver Posted May 27, 2014 Author Share Posted May 27, 2014 acad 2012, no, probably. Regardless, the fatal error ONLY occurs on a specific file. If I open another file the problem does not occur. It is probably in some lisp routine but I am not sure Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 27, 2014 Share Posted May 27, 2014 Did you try to RECOVER the file? Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 27, 2014 Share Posted May 27, 2014 I've read that this might be the cause.... entmod is triggered from an opendcl form ...but I have no idea how to fix it. Sorry. Quote Link to comment Share on other sites More sharing options...
madriver Posted May 27, 2014 Author Share Posted May 27, 2014 yes...did a recovery, purged, audit and re-named. I think it is linked to a bad lisp routine (I got the link from this site). But I am not positive, that or a bad custom hatch routine. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 28, 2014 Share Posted May 28, 2014 Attach a copy of the drawing to your next post. Someone here will take a look at it. Quote Link to comment Share on other sites More sharing options...
