Pipe tagging/elevations
hobkyl
I am trying to add elevation tags to piping, and am able to however the text size is way too small to be legible for field use. I've tried to access properties for the block, editing object display, etc etc.
How do I edit the text height for the block so that all elevation tags i put in the drawing come out as wanted?
Thanks
Find out what the block name is for the text. Go into the block editor and make sure the text Is non-annotative and 1" tall. If that does not work just build a new tag.
