Jozi68 Posted May 30, 2014 Share Posted May 30, 2014 I need a lisp routine that can take a long polyline and delete all the arc segments, thus leaving multiple shorter polylines (all consisting only of straight segments). Can anyone help me with this please? Quote Link to comment Share on other sites More sharing options...
MSasu Posted May 30, 2014 Share Posted May 30, 2014 Not sure there is really needed a custom tool; you may achieve that by built-in commands: Explode the said polyline. Call QSELECT and use an appropriate filter to select all arcs. Delete previous selected arcs. Call PEDIT in Multiple mode and select all remaining segments; next use Join option with 0.0 as Fuzz factor to rebuild the desired polylines. For sure, it may help to isolate the polyline into a temporary layer to don't interfere with other geometry; use LAYMRG when done to move result in its appropriate layer. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted May 30, 2014 Share Posted May 30, 2014 Upload an example of a sample drawing to showing before and after . Quote Link to comment Share on other sites More sharing options...
pBe Posted May 30, 2014 Share Posted May 30, 2014 I guess the OP meant by long polyline is multiple segment polylines with arc segments This is enough i think: command: _.pedit PEDIT Select polyline or [Multiple]: Enter an option [Close/Join/Width/Edit vertex/Fit/Spline/Decurve/Ltype gen/Reverse/Undo]: D Quote Link to comment Share on other sites More sharing options...
MSasu Posted May 30, 2014 Share Posted May 30, 2014 I believe that OP was looking to discard the arc segments and keep only the intermediate straight parts as multiple polylines; your solution pBe will convert them into lines, thus preserving one entity. If the arc segments were easy visually recognizable (that it, not too close to a line appearance) and in reasonable number, then may get rid of them by TRIM, too. Quote Link to comment Share on other sites More sharing options...
pBe Posted May 30, 2014 Share Posted May 30, 2014 I believe that OP was looking to discard the arc segments and keep only the intermediate straight parts as multiple polylines;... Hmmn, I guess you are right Msasu, good point Quote Link to comment Share on other sites More sharing options...
