Logic to Find Duplicate Number
vijayP
What should be the Logic to find out duplicate number from a nubmer series.
like 110 111 112 113 114 111 110 111 115 116 along with there (x,y)
For Ex. 110 is repeated 2 times
("110" ("1057.03 475.00" "821.46 436.99"))  ;;("num" ("1st x y" "2nd x y"))
111 is repeated 3 times
("111" ("614.88 467.76" "422.80 605.32" "1524.55 420.70"))  ;;("num" ("1st x y" "2nd x y" "3rd x y"))
so that we can put them in 2 tile list box. In first tile num and in second tile its all x y.
Edited by vijayP
This ... ?
(setq l '(110 111 112 113 114 111 110 111 115 116))
(foreach i l (if (not (member i lst)) (setq lst (cons i lst))))
(reverse lst)
I believe that concerned list is the enumeration from OP's statement, Tharwat; below he/she just provided examples of items.
VijayP, to list the duplicates just parse your list using FOREACH and store each element into a new one; use MEMBER to check if current element is already there - if yes, then you have a duplicate.
Tharwat; your code is returning list without duplicate but i need all duplicate and their x y. so that we can find them
Msasu; any example code?
Can you be more specific to the point ?
If you do not give a clear example of what you are after , people would keep on guessing and posting unneeded codes and maybe no one would follow your thread .
This is just for your information .
find out duplicate numbers from a nubmer series.
Tharwat; please see post #1 again
As a "Demo"...
(setq lst '(("110" ("1.6 3.3" "2.0 3.5" "1.8 2.9"))
    ("111" ("1.5 3.2" "2.0 3.5" "1.8 2.9"))
    ("112" ("1.8 3.8" "2.8 3.8" "1.0 2.0"))
    ("113" ("1.5 3.2" "2.0 3.5" "1.8 2.9"))
    ("114" ("1.0 3.0" "2.6 3.6" "1.6 2.6"))
(foreach x lst
 (if (member x tmplst)
   (setq dup-lst (cons x dup-lst));; dup-lst will retain all the duplicate
 (setq tmplst (cons x tmplst))
HTH
Henrique
