how I can draw this 2 line
wanted90
Think about it. You have twelve lines that go around in a circle. What command does that bring to mind? It starts with an "A".
The second link does not work; not that it matters.
The "R" command I hinted at is ROTATE. I'm sure you can figure out the degrees you have to rotate the lines for them to be evenly spaced on either side of the numbers on the clock/watch face.
Ok I can rotate that lines but by which dgree ?
Come on, I know you can figure this out on your own. It isn't rocket science. Look closely? Any angle immediately come to mind?
Show some confidence in your answer by telling me. You won't know if you are right until you try. Go ahead and do it; I'll wait.
Or, you could try the polar array with 24 items, and erase every other one.
You don't have to know angles for that way :D
The magic number 360.
Or even 400, or even 3.14159.......
If the OP doesn't specify, then everyone can have a guess :D
