Results 1 to 3 of 3
    Forum Newbie
    Electrical 2013
    Apr 2014
    1
    Default Electrial Project Settings
    Is it possible when Activating a project in Autocad Electrical to run a customized script or macro? Specifically, it would be nice to set the "DefaultFormatForSave" variable to the proper customer specified value.
    Thanks in advance
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,600
    It may be easier to look at creating a profile so when you start autocad everything is preset, set everything up ready to go, save a profile. Make a copy of your Desktop autocad icon then edit its properties start with name, look for /p in the startup line and make it your profile /p My20004save
    Otherwise just make a simple script and run.
    Senior Member
    pmxcad's Computer Details
    win 10
    HP Z420
    xenon
    32G
    2x
    Electrical
    pmxcad's Discipline Details
    CAD designer in safety
    Electrical
    Safety (fire,access control, cctv, intercom, evacuation, fire panels)
    AutoCAD 2014
    Apr 2011
    Netherlands
    247
    On toolbar select:
    PROJECTS >
    PROJECT-WIDE UTILITIES >
    mark: Run command script file >
    select your script file >
    OK >
    Batch Process Drawings > select project or Active drawing >
    OK.
    Done
    Script can run a LISP file, load the LISP en run the lisp in the script.
    PmxCAD
  1. Current Dim Style Settings ( LEADER SETTINGS)
    By wimal in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Jun 2013, 03:13 pm
  2. Replies: 4
    Last Post: 19th Mar 2013, 02:27 pm
  3. Settings Help, Please!
    By kyleroggenbuck in forum AutoCAD Beginners' Area
    Last Post: 11th Sep 2012, 02:15 pm
  4. Active Project settings ???
    By vertical horizons in forum Autodesk Inventor
    Last Post: 24th Apr 2010, 02:51 am
  5. 3D settings vs. classic settings
    By kmapro in forum AutoCAD Drawing Management & Output
    Last Post: 6th Aug 2007, 03:14 pm
Tags for this Thread
