Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Forum Newbie
    Civil 3D 2013
    Jun 2014
    5
    Default How do i batch convert 150+ dwg to pdf?
    Hi Guys,
    We have been supplied over 150 dwg files and I have been assigned the task of exporting them all to PDF. Is there a batch processor that is capable of doing this task? I can see software that will cost $99 and hopefully be able to do it, but im hoping to learn how to do it some other way (if possible!)
    Has anyone been down this path before and been able to do it?
    Thanks
    Forum Newbie
    Civil 3D 2013
    Jun 2014
    5
    I posted this in AutoCAD Customisation, but think the question may belong here...
    Thanks
    Senior Member
    Manufacture
    gazza_au's Discipline Details
    Engineering
    Manufacture
    Management/Stainless Fabrication/Design/Drafting
    AutoCAD 2015
    Apr 2010
    Australia
    132
    Have you got Acrobat X Pro at work?
    Convert AutoCAD files in batches
    1. Choose Adobe PDF > Batch Conversion.
    2. Specify your preferences for layers, page size, plot style, and output PDFs. Click Conversion Settings to specify the Acrobat PDFMaker settings.
    3. In the DWG List, do any of the following:
      • Click Add Folder or Add Files, and then specify the folder or files.
      • To load a previously saved list of files, click Append List, and then specify the list.
      • As needed, expand individual files and select or deselect the items you want, such as model space and layouts. To exclude or include all model space, click the associated buttons.
      • To exclude a file from the conversion, deselect the file box. As needed, select or deselect all of the files in the list, change the order of the files, remove files, or clear the list.
      • To show the complete file paths, select Expand File Name(s).
      • To save the DWG list for later use, click Save List. This action saves the list in its current state, including the file order and file selections. You can retrieve this list at any time by clicking Append List.
    4. Click Convert.
    5. Once the conversion is finished, you can click Save Details to save a log file of the conversion.
    Senior Member
    Manufacture
    Engineering
    Manufacture
    AutoCAD 2015
    Apr 2010
    Australia
    132
  5. #5
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Please check the PUBLISH built-in command.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
  6. #6
    Super Member asos2000's Avatar
    asos2000's Computer Details
    WinXP
    AutoCAD 2007
    Sep 2007
    Cairo Egypt
    679
    Is not PUBLISH do that task?
    Search on net for this progran "AcroPlot"
    Sorry for my English.
  7. #7
    Forum Newbie
    Civil 3D 2013
    Jun 2014
    5
    I am looking at PUBLISH as we speak, i think this should work for what I require. Thanks for your help guys
  8. #8
    Senior Member
    VVA's Computer Details
    Windows 7
    Intel Core i5-2400
    8 Gb
    Nvidia Quadro 600
    Seagate 500 GB + WD 750 GB
    Philips 27"
    AutoCAD 2013
    Dec 2006
    Minsk, Belarus
    447
  9. #9
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,717
    If all your dwgs are set up for layouts then using a script will do all. Only prob is individual pdf's
    http://www.cadtutor.net/forum/showth...ighlight=views
    script
    Code:
    open dwg1 (load "plotpdf") close N
    open dwg2 (load "plotpdf") close N
    open dwg3 (load "plotpdf") close N
  10. #10
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    No external program is needed. AutoCAD can produce the PDFs and you can batch plot using PUBLISH.
    Hopefully the layouts are all set-up correctly. If not there is a way to import a page set-up from within publisher.
    Drafting is a breeze.
  1. AutoCAD - Mass Convert DWG To DXF (Batch Convert DWG To DXF) (Mas DWG Convert)
    By kArThIcK hAcKeR in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 14th May 2018, 03:06 pm
  2. How can I convert dxf to dwg in batch??
    By Han_BFY in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Apr 2016, 03:48 am
  3. Batch convert dxf,dwg to pdf,jpg,bmp,gif...
    By anotherseason in forum Tutorials & Tips'n'Tricks
    Last Post: 21st Nov 2012, 06:12 pm
  4. Batch Convert DWG to RFA
    By Trevit in forum Revit General
    Last Post: 25th Jun 2012, 10:44 pm
  5. Batch convert DGN to DWG
    By sandiegophil in forum Civil 3D & LDD
    Last Post: 5th May 2011, 07:33 pm
Tags for this Thread
