Results 1 to 4 of 4
    Senior Member 3dwannab's Avatar
    3dwannab's Computer Details
    Windows 7 Ultimate x64
    Self-Built
    Rampage II Extreme
    Intel(R) Core(TM) i7 CPU 965 @ 3.20GHz
    Corsair 12GB DDR3 XMS3 PC3-12800C9 1600MHz
    ATI Radeon HD 4870 X2
    512GB SSD
    2 x WD VelociRaptor 1000 GB Hard Drives @ 7,200RPM
    32" HP LP3065 Wide LCD Moniter + 24" Dell
    Architectural
    3dwannab's Discipline Details
    arch technician and arch viz
    Architectural
    Office Tea Maker
    AutoCAD 2017
    Jun 2012
    Ireland
    160
    Default AutoCAD menu utilities loaded.; error: Automation Error. File system error
    I have a bunch of lisp in a folder on a network with an edited acaddoc.lsp in the>
    Support file search path
    Trusted Location
    in the files ACADs option.
    I've recently upgraded to 2015 and it intermittently says:
    This message only appears on some drawings. Other drawings the list of scripts in the acaddoc.lsp loads up no problem.
    Anybody else experiencing this?
    EDIT: Same setup was working in 2013
    Full Member
    MEP 2009
    Apr 2009
    53
    i am having same Error
    Self-Built
    Rampage II Extreme
    512GB SSD
    Architectural
    Architectural
    Office Tea Maker
    AutoCAD 2017
    Jun 2012
    Ireland
    160
    It ended up that it was a script that loaded up at the start which caused the problem. Once the script was found and fixed it, I never had this problem again.
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,411
    A good idea is to post the fix details for any one else I know I have to keep adding version numbers to some of my code
    Code:
    (setq vrsn (vlax-product-key))
    ((vl-string-search "R17.2" vrsn) (setq appstr "6.0")) ;09
    ((vl-string-search "R18.0" vrsn) (setq appstr "7.0")) ;10
    ((vl-string-search "R18.1" vrsn) (setq appstr "8.0")) ;11
    ((vl-string-search "R18.2" vrsn) (setq appstr "9.0")) ;12 ?
    ((vl-string-search "R19.0" vrsn) (setq appstr "10.0")) ;13
    ; 14 ???
    ; 15 ???
  1. intermitent error: Automation Error. Key not found
    By Jef! in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Apr 2014, 03:47 pm
  2. Replies: 2
    Last Post: 21st Mar 2012, 07:36 pm
  3. error: Automation Error. Object was open for read
    By muthu123 in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Jul 2010, 12:33 pm
  4. Automation error (Error 440) for AutoCAD 2009 VBA
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Oct 2009, 06:24 pm
  5. Automation error (Error 440)
    By humpieke in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jul 2007, 12:09 pm
Tags for this Thread
