+ Reply to Thread
Results 1 to 4 of 4
  1. #1
    Senior Member 3dwannab's Avatar
    Computer Details
    3dwannab's Computer Details
    Operating System:
    Windows 7 Ultimate x64
    Computer:
    Self-Built
    Motherboard:
    Rampage II Extreme
    CPU:
    Intel(R) Core(TM) i7 CPU 965 @ 3.20GHz
    RAM:
    Corsair 12GB DDR3 XMS3 PC3-12800C9 1600MHz
    Graphics:
    ATI Radeon HD 4870 X2
    Primary Storage:
    512GB SSD
    Secondary Storage:
    2 x WD VelociRaptor 1000 GB Hard Drives @ 7,200RPM
    Monitor:
    32" HP LP3065 Wide LCD Moniter + 24" Dell
    Discipline
    Architectural
    3dwannab's Discipline Details
    Occupation
    arch technician and arch viz
    Discipline
    Architectural
    Details
    Office Tea Maker
    Using
    AutoCAD 2017
    Join Date
    Jun 2012
    Location
    Ireland
    Posts
    186
    Default AutoCAD menu utilities loaded.; error: Automation Error. File system error
    I have a bunch of lisp in a folder on a network with an edited acaddoc.lsp in the>
    Support file search path
    Trusted Location
    in the files ACADs option.
    I've recently upgraded to 2015 and it intermittently says:
    This message only appears on some drawings. Other drawings the list of scripts in the acaddoc.lsp loads up no problem.
    Anybody else experiencing this?
    EDIT: Same setup was working in 2013
  2. #2
    Full Member
    Using
    MEP 2009
    Join Date
    Apr 2009
    Posts
    53
    Default
    i am having same Error
  3. #3
    Computer Details
    Operating System:
    Computer:
    Self-Built
    Motherboard:
    Rampage II Extreme
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    512GB SSD
    Secondary Storage:
    Monitor:
    Discipline
    Architectural
    Occupation
    Discipline
    Architectural
    Details
    Office Tea Maker
    Using
    AutoCAD 2017
    Join Date
    Jun 2012
    Location
    Ireland
    Posts
    186
    Default
    It ended up that it was a script that loaded up at the start which caused the problem. Once the script was found and fixed it, I never had this problem again.
  4. #4
    Quantum Mechanic BIGAL's Avatar
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,715
    Default
    A good idea is to post the fix details for any one else I know I have to keep adding version numbers to some of my code
    Code:
    (setq vrsn (vlax-product-key))
    ((vl-string-search "R17.2" vrsn) (setq appstr "6.0")) ;09
    ((vl-string-search "R18.0" vrsn) (setq appstr "7.0")) ;10
    ((vl-string-search "R18.1" vrsn) (setq appstr "8.0")) ;11
    ((vl-string-search "R18.2" vrsn) (setq appstr "9.0")) ;12 ?
    ((vl-string-search "R19.0" vrsn) (setq appstr "10.0")) ;13
    ; 14 ???
    ; 15 ???
Similar Threads
  1. intermitent error: Automation Error. Key not found
    By Jef! in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Apr 2014, 03:47 pm
  2. Replies: 2
    Last Post: 21st Mar 2012, 07:36 pm
  3. error: Automation Error. Object was open for read
    By muthu123 in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Jul 2010, 12:33 pm
  4. Automation error (Error 440) for AutoCAD 2009 VBA
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Oct 2009, 06:24 pm
  5. Automation error (Error 440)
    By humpieke in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jul 2007, 12:09 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
