Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2014
    Jun 2014
    2
    Question Object selection
    hello i need to select an object by name from VB.net application ana change it properties based on that
    can someone help me with the code used to select and manipulate an object properties ??
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,171
    More detail which object which properties.
    Forum Newbie
    AutoCAD 2014
    Jun 2014
    2
    basically what i'm trying to do is to assign a link to each object in autocad draw (walls, chairs,doors .........) so in order to do that i need to know how to select this objects based on name and change the link properties to a URL provided by me
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,171
    If you make them blocks with attributes the you can find just 1 or a common group
    Chair
    -Type
    -Number
    -colour
    -room
  1. Object selection
    By anp2012 in forum AutoCAD General
    Last Post: 30th Oct 2012, 09:17 am
  2. Trim selection & Object selection problem
    By Kurt Crim in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Aug 2011, 12:19 pm
  3. object selection
    By salman in forum AutoCAD General
    Last Post: 2nd Feb 2010, 10:18 am
  4. Object selection
    By Tekenmeester in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Jan 2010, 07:45 am
  5. object selection
    By salman in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Aug 2009, 05:04 pm
